jenkinsph
Super Star Member
You let other people use your drilling gear???
Brave man.
It is part of being in business, just another risk that is why we pay for workmen's comp here.
Brave man.
A pilot 1/3 the size of the final hole works OK for me.
I thought I had always picked pilot drills by eyeball, but when I take a look at what I'm using I tend to start with 1/8" because it is rigid enough and a common size. And then I go up so that each succeeding hole is starting in a pilot hole about half the new bit's diameter. Like several have said, I've also noticed that using too large of a pilot will chip the edge of the larger drill bits, where using too small of a pilot just causes them to heat up and dulls the edge.
Does anyone else use a Drill Doctor to sharpen bits??
rScotty
I was given a Drill Doctor as a gift. It took a little while to learn to use it effectively, but once you have the technique, it's a wonderful thing.I thought I had always picked pilot drills by eyeball, but when I take a look at what I'm using I tend to start with 1/8" because it is rigid enough and a common size. And then I go up so that each succeeding hole is starting in a pilot hole about half the new bit's diameter. Like several have said, I've also noticed that using too large of a pilot will chip the edge of the larger drill bits, where using too small of a pilot just causes them to heat up and dulls the edge.
rScotty
