Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
  1. #11
    Platinum Member o2batsea's Avatar
    Join Date
    Nov 2008
    Posts
    507
    Maryland
    Kioti DK45C 2005
    Default Re: Gathering Materials for a Homemade Snow Cab for my John Deere X300
    Quote Originally Posted by stugpanzer View Post
    I worked on the plywood top today (pics to follow in a day or so). I used my router to round the top edges and a palm sander to just smooth it out a bit. I plan on using Fiberglass Resin without the actual glass to paint onto the wood and especially the edges to seal the wood then I will paint it.
    I recommend epoxy resin. Gives far better results on bare wood. Your first few coats thin with 50% xylene. That will soak deep into the wood. Allow a full day between coats. After you get a couple coats then hit it with 60 paper. Next put a single layer of cloth. Lay it on dry. Push all the wrinkles out and leave it draped over the edge. Pour straight epoxy resin on and use a plastic scraper (like for bondo) to push it down into the cloth evenly. After a while trim the draped excess when the resin is leather hard and not tacky. Next day after it is fully hard, hit it with 120 paper. With a roller, add another couple coats to completely fill the cloth and bring up the surface. Final sand and paint with 2part epoxy primer followed by your topcoat.
    You can also make a lighter weight top by bending up a perimeter frame and a couple arced ribs. The ends of your perimeter should be the same arc as the ribs. Use the textured 1/8 thick fiberglass panel from lowes or Home Depot as your cover (the cheesy stuff they line bathrooms with). Pop rivet the stuff every 4 or so inches to your frame. Trim with shears so you leave an inch or so drip edge. Light, strong and cheeeeeeep.
    Practicing the ancient oriental art of ren-ching.
  2. #12
    New Member
    Join Date
    Jul 2017
    Posts
    16
    Sandwich
    John Deere X300
    Quote Originally Posted by Egon View Post
    Go with a heated snowmobile suit and full helmet, heated boots & gloves. Toasty warm. Add a good light on the helmet and where ever you look will be lit up.
    Now this is funny! I have many reasons for wanting to tackle this project an dno real good reasons for 'needing' it!
  3. #13
    New Member
    Join Date
    Jul 2017
    Posts
    16
    Sandwich
    John Deere X300
    Quote Originally Posted by chim View Post
    Here's a source for fairly inexpensive steel fittings. They have them for 3/4" EMT to 1-7/8" OD pipe. The eye bolts don't appeal to me but they could be replaced with HHMS:
    Canopy Fittings and Portable Shelter Connectors
    I have seen these types of connectors. I could make some as well with 1" conduit but then what would I use my 3d printer for? LOL
  4. #14
    New Member
    Join Date
    Jul 2017
    Posts
    16
    Sandwich
    John Deere X300
    Quote Originally Posted by o2batsea View Post
    I opted for the Fiberglass Resin. i don't intend on making this perfect...just water proof or at least water resistant. I will be painting the top as well.
  5. #15
    New Member
    Join Date
    Jul 2017
    Posts
    16
    Sandwich
    John Deere X300
    So I measured and cut a 3/4 piece of plywood to the desired size for my snow cab roof.
    I used my router to round one edge which will be the top:
    Gathering Materials for a Homemade Snow Cab for my John Deere X300-4-jpg
    I put some wax paper down onto the work surface under the plywood:
    Gathering Materials for a Homemade Snow Cab for my John Deere X300-5-jpg
    I applied the resin on the plywood top and sides:
    Gathering Materials for a Homemade Snow Cab for my John Deere X300-6-jpg
    Next steps will be to do the underside and then I want to really get the edges with one more coat. Once I am done with the resin I will paint it probably with Rustolemm Enamel paint.
    I am also scoping out the frame of the tractor to determine what/where my attach points will be for the cab.
    More to come.....
  6. #16
    Gold Member
    Join Date
    Feb 2015
    Posts
    261
    Collegeville, PA
    Kubota B8200
    If you're going to make the roof wood, you're going to be top heavy, no matter how well you secure it.
    Here's my plywood cab, around 6:05 I do a walk-around off it: IMG 16 - YouTube
    It's top heavy. It sways. This is why I made my new cab out of sheet aluminum. Not to expensive, very light, and very sturdy.
    1951 Ferguson TO-30 FEL
    1953 Oliver 77 Industrial TLB
    1971 New Holland S-14 - Snowthrower, Plow, Cab
    1986 Kubota B8200
  7. #17
    New Member
    Join Date
    Jul 2017
    Posts
    16
    Sandwich
    John Deere X300
    Quote Originally Posted by fatjay View Post
    Hmmmm, I will have to consider this. Thank you!
  8. #18
    Gold Member
    Join Date
    Feb 2015
    Posts
    261
    Collegeville, PA
    Kubota B8200
    When ever I run over a lump of snow or curb when in that tractor, the whole thing sways. It's secure, but still, it definitely moves.
    Almost forgot, if you go to remove it, it's going to be VERY HEAVY!
    1986 Kubota B8200
  9. #19
    Gold Member msb1766's Avatar
    Join Date
    Oct 2007
    Posts
    466
    Guilderland, New York
    SC2450 Cub Cadet/Yanmar
    I made mine out of wood and yes it is top heavy, Put a couple of bolts at the bottom of the cab to hold it down.
    Gathering Materials for a Homemade Snow Cab for my John Deere X300-img_1188-jpgGathering Materials for a Homemade Snow Cab for my John Deere X300-img_1189-jpgGathering Materials for a Homemade Snow Cab for my John Deere X300-img_1190-jpgGathering Materials for a Homemade Snow Cab for my John Deere X300-img_1191-jpg
    Gathering Materials for a Homemade Snow Cab for my John Deere X300-img_1192-jpgGathering Materials for a Homemade Snow Cab for my John Deere X300-img_1193-jpgGathering Materials for a Homemade Snow Cab for my John Deere X300-img_1194-jpg
    Cub Cadet/Yanmar TLB Sc2450, Ratchet Rake, Front Snowblower, Back Blade, Spreader, Middlebuster, Homemade Ballast, Homemade Cab
    CUB CADET RZTL54FAB
    Craftsman GT5000
    Wheelhorse GT-14
  10. #20
    New Member
    Join Date
    Jul 2017
    Posts
    16
    Sandwich
    John Deere X300
    Repaired my 3d Printer and so now I am printing some 45's!
    Gathering Materials for a Homemade Snow Cab for my John Deere X300-7-jpg
Similar Threads
  1. Replies: 3
    Last Post: 08-28-2017, 05:08 PM
  2. Snow Plow for Deere X300
    By RBLapham in forum Customization
    Last Post: 05-10-2017, 07:04 PM
  3. Snow Plow for Deere X300
    Last Post: 05-04-2017, 11:46 AM
  4. John Deere 855/955 Cab & snow blower
    By JD Bob in forum Private Party Ads
    Last Post: 01-16-2013, 02:14 PM
  5. HOMEMADE SNOW CAB
    By chefirv in forum Build-It Yourself
    Last Post: 01-21-2011, 04:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
