Big Barn
Super Member
- Joined
- Aug 20, 2013
- Messages
- 7,023
- Location
- Victoria, B C
- Tractor
- More than 40 over the years. Ten at any one time. Mostly Ford and New Holland
If the tool requires air volume that is at, or near the limit of what you are supplying it, like a decent sized air grinder, perhaps you could see a difference.
Most tools, that use 1/4" fittings, don't draw a lot of volume, so it won't matter.
If you are concerned about that restriction, eliminate the fitting. Connect the hose directly to the supply line. I would install a ball valve before the hose, so you can turn it off when you have a failure.
My Nitto Koiki angle grinder uses 20 CFM. (.9 HP). I've used the same style 3/8 hi flow automotive couplers in my shop for almost 40 years.
Good plan on installing ball valves. I use ones with an exhaust port. Makes attaching / re-attaching easier.
Terry
