BrokenTrack
- Joined
- Jan 13, 2018
- Messages
- 1,551
- Location
- Maine
- Tractor
- Tractors, Skidders, Bulldozers, Forestry Equipment
I got a skidder, but as my wife will attest, I only smile when I am on my bulldozer.
One of the problems with my bulldozer is that it does not have a winch, and a factory one costs about $5,000 to install...used! Yet...when I am logging, I am often inefficient because with direct attached chokers I have to get really close to my felled trees. As the trees add up on back of the bulldozer, it gets harder to do this. Alternatively, if a choker pops loose, I cannot back up and retrieve the log making a less-than-full twitch out of the woods; again...inefficient logging.
So while a tractor farm winch is not ideal, it can at least sneak back into the woods 150 feet and bring trees to the bulldozer as it makes up its twitch. To that end I fabricated my own 3 point hitch and pto drive. Again 3 point hitches can be factory installed, but they are about as rare as finding a hens tooth while balancing upon a unicorn's horn. The PTO was just a matter of changing out the final drive cover with a winch drive cover with shaft ($150), and then adding a 1000 pto to 540 pto spline adapter ($21).
Again it is not as good as a factory installed hydraulic winch, but at least I can now gather wood up so that I can make a twitch of wood.
(Note: In this picture I was just finishing up with my reverser rebuild, transmission cooler add-on, and did not get the engine shroud and ROPS back on when I took the photo).
