Rustyiron
Super Member
I'm building a (snow) pusher box for the 3 pt. hitch. Mostly for pulling snow away from doorways & garage doors. I run a Fisher V blade on the front of the tractor that is mounted to the frame. It's sort of a cross between a regular "box blade" and a pusher, but with a twist. I started designing a more normal box blade type that had swing out side plates that could hydraulically be set anywhere from the "normal" box blade position to pointing 180* backwards allowing it to be a pusher while backing up, to a 12' wide straight scraper blade. Some of the bigger lot's I plow would save some time pushing snow while on my way back in reverse (win rowing) trip that otherwise is wasted time. My CAD skills are limited to Cardboard Aided Design (stolen from another TBN member
) and I could not come up with a linkage to get 180* rotation out of a cylinder so I came up with the idea of a more normal designed pusher box that the 3 point attachment portion would uncouple from the box and mount on either side of it for pulling snow away from doors.
This is where I'm at right now.
I got some old cutting edges from the town's garage that were worn out and cut them down to a straight edge that I'll never wear out, at least on a tractor, they are 5/8" thick!
The "box" is pretty much done and I'm working on the attachment then the actual 3pt hitch. I'm doing a variation of the "euro-global" type connection that should be easy to switch around with only a couple of pins to attach it. I have a hyd. top link that will aid in this hook up.
