LD1
Epic Contributor
Not really a good forum to post this in.....and not a member of anywhere else that may yield better answers....but figure with many people here someone might know.
Here is the dilema. I have a Famco #2 arbor press....rated at 2 tons, and a 35:1 leverage ratio.
Also have a famco 3-1/2R arbor press rated at 5 tons and 70:1 leverage ratio
The job is punching some sheet metal holes. And to my surprise, the smaller famco #2 punches just as easy as the larger.....3-1/2r which is supposed to have 2-1/2 times the force.
So started doing some digging of just how they come up with their leverage ratios and force calculations and all that.
the smaller famco has a pitch radius of 0.70 and a lever arm of 24.....which calculates pretty close to the 35:1 leverage ratio. Meaning that 114# hanging on its 24" arm should yield the 2-ton claimed. And I have no doubt that it does just that.
However, the 3-1/2R only has a 1" pitch radius, and a 35" arm.
So how in the world are they coming up with a 70:1 leverage ratio.
To get 5-ton rating....at 70:1....should only need 142# hanging from its 35" arm....which is very attainable. But in reality.....I am only getting a 35:1 ratio.....even with the longer arm. Meaning its no stronger than the small benchtop famco #2???
So what gives? I know this is an older press. did it originally have a 70" handle???(which would seem odd)? Dont really know how someone would change the pitch diameter. everything looks original?
Is this just a case of marketing gimmicks like everything else that ratings are bogus on...like logsplitter tonnage, etc?
