Beltzington
This isn't tractor related but I know many of you are experienced DIY and/or professional contractors.
I am remodeling our master bathroom and installing a large walk-in shower where the previous owners had a large whirlpool tub. The problem is there is an outside window where the back wall of the new shower will be and since the window is right over the back-deck there is a privacy issue in addition to preventing interior water damage. To complicate matters the outside wall is brick so the window flashing is not accessible without removing brick and if remove the window I will have a large hole I will have to fix.
My question is there any structural or building code issues with just leaving the window installed and framing and tiling over it on the inside shower wall? The widow is single hung thermal pane metal frame in good shape. I'll likely cover it on the outside with a solid pane of stained glass just to disguise the fact the window is not functional and provide some decoration for the deck.
My gut feeling is this a half-xxx way of doing this but the more I think about it the more it makes sense, even if I remove the window, tear out the brick, repair the sheathing, and brick it over it will be obvious as I do not have any of the original matching bricks. Also, this is the first time I have ever actually had the window open to use it as a trash chute.
Does a window have to be a window? What are your thoughts.
