Bob_Skurka
Super Member
- Joined
- Jul 1, 2003
- Messages
- 7,503
I wanted a set of pallet forks to attach the the 3 point hitch but was not happy with the pallet lifters that are for sale from the various implement companies. Most 3pt pallet lifters do not allow for moveable and replacable forks. Most are simple fixed units. I wanted real pallet forks, I wanted lateral movement. And I had no clue how to get what I wanted.
This thread is a series of pictures that start with a basic Howse frame and show how it can be converted, by simply inserting Top Link Pins into holes, to become a pallet lifter. If you only want to see the pallet lifter, skip down a few posts and start looking at the pictures.
Then I had an idea to use the basic frame from a Howse Sub-Soiler, Middle Buster, Trailer Hitch combo unit that I got for about $150 a year or two ago.
My main purpose of buying the Howse unit was to modify the Sub-Soiler and use it to bury cable. But I have found that I have modified more the Sub-Soiler. The pallet fork project is just the latest modification.
Initially I replaced the 2 standard bolts that are used to hold the Sub Soiler, the Middle Buster & the trailer hitch in place. I simple took out the bolts and substituted them with Top Link Pins.
I also drilled 2 holes in the trailing edge of the Sub-Soiler, took 2 hose clamps, and clamped a plastic pipe to the rear edge so that I could bury cable. It worked perfectly.
See the attached picture of the Howse unit.
