Results 1 to 6 of 6
  1. #1
    Silver Member RickO's Avatar
    Join Date
    Jan 2005
    Posts
    231
    Central, Ohio
    Kubota G1900
    Default Building a lawn rake
    Anyone have ideas on how to build a good drag that helps smooth out the soil after tilling? I wonder if something similar to the TR3 rake could be fabricated?
  2. #2
    Join Date
    Jul 2003
    Posts
    1,969
    Kansas
    2003 BX2200
    Default Re: Building a lawn rake
    Here's a harrow I built as a multifuntion tool. I can drop the harrow and insert a scarifier to trench. Later I plan to add mounts so I can add 4 more scarifiers for a chisel plow type tool. (This is an early pic as I've added a piece of steel to replace the 2x4!)
    This harow works well after tilling to create valleys for seed. I've used it, laid out the seed, then went over the yard again to "rake" it in. Works fine.
    Mine's not as complex as a TR3 type tool.
    Attached Images Attached Images
  3. #3
    Join Date
    Sep 2002
    Posts
    1,612
    Mt. Ulla, NC
    Satoh S-470D, Mitubishi FD 1450D
    You might try some farm machinery auctions or dealers to find a used drag harrow.
  4. #4
    Join Date
    Jan 2005
    Posts
    231
    Central, Ohio
    Kubota G1900
    Thanks for the ideas!
  5. #5
    Join Date
    Oct 2004
    Posts
    164
    Nebraska, USA
    Ford 8N, International 454, Farmall M
    I smoothed out my lawn with a 6' piece of chain-link fence pulled bhind my 8N. Worked GREAT!
  6. #6
    Join Date
    Mar 2004
    Posts
    92
    North Mississippi / Nash Ridge
    Kubota BX2230/Ramrod mini skid loader/Carlton stump cutter
    Anybody know what a TR3 cost new, just a ball park est.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
