55 gallon drum sprayer
   / 55 gallon drum sprayer #1
DelfinoTX
Rio Grande Valley, Texas
Here are some pictures of a sprayer I made last year. Purchased the roller pump, regulator and spray wand at TSC.
The rest of the nylon fittings were purchased at my local harware store. I mainly use it to spray fence lines. I first used a Shureflo electric pump (you can see the base I mounted it too in the pic), but that wasn't powerful enough. The roller pump can produce up to 200 psi with the tractor idling! I usally spray at 125 psi.
I used high presure hose to connect to the roller pump with regular hose bib connectors. Very easy to find and no tools needed.
Made the cradle a little less wide than the drum for a snug fit.
Drum is secured by a single nylon strap.
Used two street ells with hose bib adapters for easy hookup.
The pump has "FLUSH WITH OIL AFTER USE" on it, so thats what I do. The caps keep the oil from draining out during storage.
   / 55 gallon drum sprayer #8
</font><font color="blue" class="small">( FLUSH WITH OIL AFTER USE )</font>
Yes sir, and if you store it with oil, or antifreeze, in it, it'll last for years. If not, it'll corrode and be hard to turn after awhile. That's a real nice looking setup you have.
   / 55 gallon drum sprayer #9
Excellent looking project.
I really appreciate you posting information about your sprayer. Im gonna try and make one just like that. It's exactly what I want. /forums/images/graemlins/smile.gif
dwight
SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2004 PETERBILT 379 9 CAR HAULER (A52577)
2004 PETERBILT 379...
2008 IC Corporation PB205 Bus, VIN # 4DRBVAANX8A506494 (A51572)
2008 IC...
2017 Ford F-250 Crew Cab Pickup Truck (A51692)
2017 Ford F-250...
