Building a small scale thresher
   / Building a small scale thresher #21
One last picture.
Sorry it has taken a few days to get back, but I have not been on-line. I will contact ITDG (I think they have moved) but would appreciate the title of the book/publication that the photos were in. Old McDonald.
   / Building a small scale thresher #23
Tools for Homesteader, Gardeners and Small-Scale Farmers. Published by Rodale Press and Intermediate Technology Publications Limited. 1978.
I am amazed that this kind of stuff has not yet made it to the web where it could benefit people living in out of the way places.
Here is something I came across the other day
http://www.vintageprojects.com
My sentiments exactly. There is simply no second hand market here (except for trade-in tractors) and anyone with slightly more than the amount of land that can be handled by donkey power is relying on buying new, or. as I have just done, contracting - and that is limited to haymaking. Not a combine harvester anywhere in the vicinty. Reaper binders there are, hence the need for a thresher!!!! Thanks for the other info, and the site looks interesting from a quick glance, I will have a better look later. Old McDonald.
   / Building a small scale thresher #26
Class Definition for Class 460 - CROP THRESHING OR SEPARATING
or the second one is more printable,
http://www.uspto.gov/go/classification/uspc460/defs460.pdf
dkimages - discover - technology - Combine Harvesters
Wheat -- The Inside Story
this is the closest I can come to "plans" no dimensions but usually the drawing are more or less to scale on each page.
thresher - Google Patents
try some different phrases grain separator, cleaner, thresher, wheat ------ ,rice, combine,
one thing to remember about patents, there ideas that have been registered, and that is all, not necessarily good or bad, but ideas, that some one went to the work of registering, not all of them are worth repeating or are they all poor, I guess in simple just because it was patented does not automatically make it good. the Patent protects the idea for few years an after that it is free to use, and if you doing it for your self and not profit on it I do not think there is any thing can even be said on one in force. depending on the type of patent it is the time is 14 or 20 years from the filing of it. What is the Difference Between a Design Patent and a Utility Patent? Patent - Wikipedia, the free encyclopedia
I usaly open them up in the PDF format, in my oppion it is easer to see and use.
   / Building a small scale thresher #27
I nearly forgot, a few years ago I made a grass seed harvester, that I pull behind the tractor and it uses a form of a spinning brush to knock the seed off the stock of the plant, it is a "stripper", and I think it would work for small scale grain harvest, one would still need cleaner of some type to blow out the chaff and so on,
the brush (which I made from string trimmer string), rotates turning upward and it has a hood and a box on the back side that it throws much of the seed into, that has a screen over it, so one does not jsut blow it out back,
Prairie Habitats - Pull Type Seed Strippers
the one on this page is similar to what I made.
Seedburo Equipment Company - Pull Type Seed Stripper
I totally missed the 2008 and 2009 posts. The hand feed ideas are too small scale for the area I and my neighbours grow except if we grow a tiny area of wheat for breadmaking. I tried this in 2006 or 7 and it was too time consuming. I did not make a static one for this reason. I also ended up buying a reaper type mower for my few acres of hay on shares with a neighbour and we are considering cutting with this then picking up with a baler type pick up and into a threshing drum attached. No plans drawn up yet, just ideas.
2015 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
TPM 10 Piece Mini Excavator Heavy Duty Attachment Set (New/Unused) (A59225)
TPM 10 Piece Mini...
2011 Komatsu GD655-5 Motor Grader, S/N 55088 C014007, PIN# KMTGD026P01055088, Turbo Diesel Engine, (A59076)
2011 Komatsu...
2021 Ford F350 XL (A57148)
2021 Ford F350 XL...
E-Z BOAT TRAILER (A58374)
E-Z BOAT TRAILER...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
