Building a small scale thresher
   / Building a small scale thresher #1
OldMcDonald
Mainland, Orkney Islands.
None
I have searched the Web in vain for several months to find plans to guide me in building a small thresher. I have found photographs of treadle operated ones in China and small motorised ones in India, but not enough detail to let me proceed. I realise this is an unusual request but, can anyone please help?
For info - I live in inland Portugal where the used equipment market is non-existent. Donkey power is common, and probably even best described as "normal" . Land holdings are very small (my 16 acres is considerably bigger than usual) and threshing, if done at all, is by flail. I will be growing up to 5 acres of oats, beans or lupins at anyone time, and probably a smaller acreage of corn. Cutting will be by an old fashioned bar mower with a binding attachment, with corn cobs hand picked. Not sure if you also call the result sheaves in US. I can buy metal and have my own welder (already had to make other things) but fancy bits and pieces are not really available. Treadle or pto operated (45hp NH) is OK. Probably prefer treadle and do it indoors in winter. A static baler would also be a useful thing to have!!
   / Building a small scale thresher #2
If there was a larger farm somewhere you could do what some Menonites use in a town a peice from here. They took a large old combine that was junked and cut off the and all the running gear and drive train. It left the main body of the combine with just the treshing and seperating gear. The input shaft on the transmission was attached to the tractors pto and they used it to thresh wheat, corn, beans and dry peas. Its in a barn and uses a long pto shaft to operate it. they Thresh all the locals wheat and corn for shares of the product and have a stationary baler in the same building to bale the wheat straw and bean left overs.
Thanks, but as I said, there is no used machinery market, purely and simply because no-one has them. I am sure that the rest of the world is not aware that the rural population of Portugal (and maybe other western European countries) just do not have the machinery and equipment that has been taken for granted since WWII in the so-called "civilised" world.
   / Building a small scale thresher #4
would some pictures of the insides of an old combine help with your fabrication of one. Im about to gas axe a John Deer 45 Combine and also a 205 Massey Ferguson combine. I make other things out of their parts. THey have a cylinder with teeth that engage a concave grate thet flail the beeans and wheat and oats to shell them and seperate them from the chaff.
   / Building a small scale thresher #5
As I recall, a JD 45 is not that large a machine (in today's standards for combines). Maybe someone has a parts manual for one of those. The parts book would show many details that might help him build his own......
Anyone got one?????????????
Ron
   / Building a small scale thresher #6
Try looking thru www.jdparts.com - if you knew the model numbers of some of these machines you might be able to find the parts diagrams. They claim to have most of the John Deere stuff going back to 1975 online.
   / Building a small scale thresher #7
Hi,
As someone on this side of the pond and in Europe (!) my take would be to find a machinery dealer somwhere in Europe and buy what you need as scrap, the concept of manufacturing your own seems an awesome project to undertake given the need for quite complex and reasonably precise machining for some of the drive components.
There are firms in the uk that regularly export very old kit and there are great secondhand machinery dealers in Holland who you might be able to do a deal with.
I fear you would spend a considerable amount of time and effort in re-inventing the wheel so to speak and having to change things as the project evolved.
Maybe not the very best answer since we are keen to make things but if you are, as I suspect , making a living from your 16 acres (8 ha) then to quote an old adage 'time = money'
I know this won't 'solve' your request but is perhapsa more pragmatic solution.
Best of luck Densleigh
Taylortractornut, Yes they would, thanks very much. Hole sizes in screens are important, I have seen a commercial combine that suggests 3/4 inch (19mm) for corn but no others. Clearance behind screen is probably also important. Know anything about beater sizes and clearances? I can live without straw walkers.
Densleigh, Yes, I know all about scrappies and freighting here. I have contacts in various places but it is a 4 day drive from Holland, 5 and a sea trip from UK, so it is just plain uneconomic for 5 acres a year. The treadle machine on taoyan.randdf.com is just about passable if I had the dimensions, although something a bit more sophisticated is preferred. Old McDonald.
I am no further forward than I was 6 months ago. Please, anybody, anywhere, make a guess at what you would do if you absolutely must thresh some wheat for grinding so you could make bread. Somebody must have some ideas.
   / Building a small scale thresher #10
I've seen several done to match 1/2 or 1/4 scale tractors. I was going to try it myself, until I started thinking about all the hours these guys have into them; so I stick to the full size one [which I haven't had the chance to play with in a few years at that /forums/images/graemlins/frown.gif].
That being said, I think you have plenty of options.
You could go wayyyy old school and flail it on a wood floor....pitch fork for the straw, sweep it all up, and fanning mill for the chaff.
More reasonable, with the mfg skills I'm assuming you have, and assuming your mosly interested in small grains, a treadle operated cylinder should be easy (but you will need to feed it slow, it takes more power than you think to keep up the RPMs for threshing). The reason I say easy is that for small grains you can make a tooth cylinder and concaves then the clearance doesn't matter quite as much [on the other hand to avoid making 100 teeth, you could likely spend some time with trial and error of clearances of a "straight cylinder"]. For small grains the hole size on the concaves will be very forgiving too. I'd start with, perhaps, a couple 12" diameter disks then connect them with a shaft (long enough to have bearings and your pully or crank). Then run about a dozen peices of 1/4" X 1" steel [or lighter, shallow 1/8 wall channel]. Make concaves as a negative of this and about 10-20% of the circumferance - don't forget to account for clearances and/or teeth; on the concaves you'll likely have the best results leaving little gap bettween the bars, but perhaps drilling plenty of 1/2 inch holes. Of course, the cylinder isn't the reason threshers are so big; it's the "separator" part [straw "walkers" to reduce the work for the sieves, a least one set of sieves, and a built in fanning mill for the chaff, but I think you allready have ways to deal with that.
Good Luck.... I want pictures!
CATERPILLAR 259D3 SKID STEER (A51242)
CATERPILLAR 259D3...
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A51222)
2025 REDEDLIFT...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52128)
Koyker Loader...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2021 Takeuchi TL12V2 Skid Steer (A51242)
2021 Takeuchi...
