Page 6 of 8 FirstFirst ... 345678 LastLast
Results 51 to 60 of 75
  1. #51
    Super Member Highbeam's Avatar
    Join Date
    Feb 2005
    Posts
    5,039
    South Puget Sound, WA
    Kioti CK30HST
    Default Re: Harbor Freight Generator head 10kw
    Off the machine
    Attached Images Attached Images
  2. #52
    Gold Member
    Join Date
    Nov 2003
    Posts
    298
    Omaha area
    LK3054
    Got the thing running today. The synco-cog belt is smooth. Ran my 3hp air compressor. Whats great is each time I would start the compressor it would only drop about 4 volts and return extremely fast. Frequency would only drop to 56hz and then go back to 59.9 according to the Fluke 87 meter. And that is with the air compressor hot. The Coleman Powermate would drop almost 15 volts and frequency would bounce from mid 50s to mid 60s before stablizing from the govener and let out a puff of black smoke.
    For one the big difference is the rotational mass is significantly higher with the HF head and pulleys. The powermate has very little mass to speak of.
    Now I need to work on making it quieter. I don't think its much quieter than the Powermate which is obnoxious, just more cylinders barking in harmony. Not too shabby.
    thx
    Jim
  3. #53
    Platinum Member Lazy's Avatar
    Join Date
    Dec 2003
    Posts
    516
    Missouri
    ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
    Hi
    check out these rex couplers web page we used these where I worked before retiring and they were much better than any other type. didn't have the alignment problems we had with the lovejoy or falk. The chain type had to be near perfect in alignment.
    Charlie
  4. #54
    Join Date
    Nov 2004
    Posts
    82
    Lawrence, KS
    Farm Pro 2425, Ford 8N
    Jim, I'd like to show you a photo or two of an old military generator, that has a very impressive control panel. The wiring schematics were printed in 1953. It has a very small continental engine in it. ( Friend brought it out to me - major engine problems.) It appears to be 9K-10K output generator. Since it is military, it does have 120v,240v single phase and 3-phase capabilities. The control panel does have a volt meter, amp meter, cycle meter (50-70 cycles), and an hour meter. Of course there is a selector switch for various voltages and phases. Good luck with your project. Just thought you might be interested in seeing this one. Yugo
  5. #55
    Join Date
    Nov 2004
    Posts
    82
    Lawrence, KS
    Jim - here's the second picture of military generator. - Yugo
  6. #56
    Join Date
    Jun 2005
    Posts
    1
    SW Ohio
    Can anyone provide more info about this "Ohio" connection? I'd greatly appreciate it.
    TIA
  7. #57
    Gold Member
    Join Date
    Nov 2003
    Posts
    298
    Omaha area
    LK3054
    Heres the current work in progress of the genset with the military surplus engine. Still in the raw stage. Much work left to do. But it does run my air compressor just fine. Engine runs at 3000 rpm and the generator at 3600.
    thx
    Jim
  8. #58
    Gold Member
    Join Date
    Nov 2003
    Posts
    298
    Omaha area
    LK3054
    Drive side. Yes there will be shields.
    thx
    Jim
  9. #59
    Join Date
    Jul 2005
    Posts
    1
    I'm new here and was following this thread.
    I plan on doing the same with a generator head.
    What about speed regulation?
    I was thinking about using a VW rabbit diesel
    motor.Any ideas?
    Thanks
    Doug
  10. #60
    Gold Member
    Join Date
    Nov 2003
    Posts
    298
    Omaha area
    LK3054
    Doug,
    I missed getting a hold of a Volkswagon diesel. Could have had it for $150.
    With my experience from this project your two biggest challenges would be the speed governor and fabricating the coupler, either belt or direct drive.
    The military engine I'm using has a mechanical governor very simular to this one at Surpluscenter.com.
    http://www.surpluscenter.com/item.as...1&catname=
    The trick would be getting oil feed to it, but it works fantastic on mine. And for $29 bucks it would be worth trying.
    thx
    Jim
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
