Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Mar 2005
    Posts
    151
    Central Indiana
    Jepe 354
    Default Log Splitter makeover, with log lifter
    A few years ago I built this logsplitter, but the axle and wheels did not allow for towing behind the tractor or truck. I had used a 3/4" axle with wheel borrow tires, and towed it behind the 4 wheeler or had to load it on a trailer to transport. In the makeover, I bought an old popup camper and used the axle and springs as a starting point. Used the tractor to lift the splitter up while cutting the old axle off, and then lowered onto new axle and towable frame. I figured now would be a good time to add a log lift. With an order to Northern, and a few trips to the parts store the splitter is now up and running great. I still want to add chainsaw storage, on the deck and maybe a place for the gas can.
    I would also like to update the 11gpm pump but the budget took quite a hit with all the new parts. I used a Prince logsplitter valve and added a Prince Priority Flow Divider which helped slow down the lift cylinder speed and speed up the splitter cylinder. Just had to share with fellow wood burners. [img]/forums/images/graemlins/grin.gif[/img]
    Attached Images Attached Images
  2. #2
    Join Date
    Dec 2003
    Posts
    769
    not heaven but you can see it from here... Brown County , Southern In.
    Branson (kukje) 4020, 40hp turbo
    Default Re: Log Splitter makeover, with log lifter
    Bigbear, I admire people who can fabricate with metal. I have been using a wood furnace for 20 yrs now, and decided early on to invest in a good splitter. I have no welding skills of my own, so I ended up buying a splitter from Northern that had a log lift. It was expensive at the time, but I see now they are almost twice as much in cost. Without a doubt, the log lift is the handiest thing and well worth the money. Also the splitter sits high, so the operator does not have to bend over. My log lift sits the right side of the spliter (looking from behind) and has a 1 ft tray on the left side. Maybe 3 things I would do different to mine..... 1) the log lift just has a couple cross members welded in to keep logs from falling through...seems like your expanded metal is better , 2) fabricate a set of removable trays to attach to the tongue of the trailer... (behind the splitter bar) to catch the wood after being split. You could remove easily when towing the trailer). , 3) the tray on the northern is 1/8 inch and the operator tends to push their thighs into it when operating. This gets old after a day of operation. I cut a piece of garden hose and cut a slit in it to fit over the edge. Somehow the edge needs be be rolled over or made so it is easier to lean against. Good luck with your splitter....looks very well done.
    sassafraspete
  3. #3
    Join Date
    Dec 2003
    Posts
    769
    just looking at your design again... seems like having the motor up front and working end at the back makes sense , as you can leave attached to the vehicle and have plenty of room to work from behind. Also, with your splitter mounted on the ram, there is no need to have the extension trays that I mentioned, since in yours....it seems it would fall on exsiting trays / lift. Does that log lift work better being on the operator's side ? Seems like if it is not in your way, that having the lift up makes a nice table to feed logs from and you are not reaching over the I-beam.
  4. #4
    Join Date
    Mar 2005
    Posts
    151
    Central Indiana
    Jepe 354
    Thanks sassafraspete, I operate the splitter from the motor side, the lift makes a great place to hold the other half of large logs you are splitting, don't have to bend over and pick up the other half. I try and back the truck or trailer up pretty close to the back of the splitter and just toss the pcs in when split. The smaller ones to be split I keep right behind me, so all I need do is turn around and pick up another one. If you have a helper (young sons), they could keep logs on the lift and the old man would not have to bend over as much. [img]/forums/images/graemlins/grin.gif[/img]
    I will take some action shots when splitting, and maybe see how big a pc the lift will take.
  5. #5
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    Where do you stand to operate this? The frame appears to be in the way to stand up very close to the log being split, resulting in a lot of bending over.
    I like the lift.
    Seems an off-loading table would be helpful on the opposite side of the lift.
    Nice work.
  6. #6
    Join Date
    Mar 2005
    Posts
    151
    Central Indiana
    Jepe 354
    Maybe this picture will help. [img]/forums/images/graemlins/grin.gif[/img]
  7. #7
    Join Date
    Dec 2003
    Posts
    769
    Bigbear... that does look like central Indiana in the background of your picture, but I swear I didn't know Santa Claus burned wood too... [img]/forums/images/graemlins/grin.gif[/img]
  8. #8
    Join Date
    Mar 2005
    Posts
    151
    Central Indiana
    Jepe 354
    That's funny (sassafraspete) haven't heard anything that funny since I got back from Nam the first time. Semper Fi
  9. #9
    DMF
    DMF is offline
    Platinum Member DMF's Avatar
    Join Date
    May 2005
    Posts
    623
    Mass
    Massey Ferguson 1552 Cab Model
    Nice looking splitter BigBear. What is that beast of a truck in front of it; looks like it's lifted a bit...
    Thanks for your sacrifice to serve this great country!
  10. #10
    Join Date
    Mar 2005
    Posts
    151
    Central Indiana
    Jepe 354
    Thanks DMF, it's a little Toyota 4x4 flatbed, with a big heart. I use the little 4 cylinder to pull the tractor with backhoe on an 18' dovetail trailer. It also gets a workout in the woods, or hauling firewood. Before I bought it, a teenager had it with monster tires on it, and ran it rather hard [img]/forums/images/graemlins/frown.gif[/img]. Not sure if it's any better off with me or not. [img]/forums/images/graemlins/grin.gif[/img]
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
