</font><font color="blue" class="small">( ...you have it extended way out there so that it might have a tendancy to tip forward. )</font>
Thanks, Tractors4u, for your words of wisdom. You made a good point.
With the boom horizontal, the load is a little over 4 times farther in front of the front axle than just the bucket. So I figured that it could lift a little under 1/4 of the max. bucket load without a tipping problem. Conservatively, I put that at 250 lb.Once the boom gets angled up in the air, the load gets closer to the front axle and the tipping tendency gets a lot less.
Still, I was pretty darn careful the first time I picked up one of the poles, but I didn't feel any sense of the rear end getting light, and once the pole was vertical the tractor felt nice and stable as I moved the pole around.
And yes, the rear wheels are loaded. /forums/images/graemlins/smile.gif
Tom
