Ballast Block
   / Ballast Block #1
keeney
Minnesota
JD 4100 HST
Ballast block for use with my 4100 / 410 loader.
10-1/2 sacks of quick-crete.
Two 3/16" flats with 3/4" hole dilled through the end welded to an off-the-shelf cat-1 drawbar.
Some additional rebar thrown into the forms in case it cracks.
Estimated weight = 900 lbs.
I tapered the front so it nestles tight to the tractor - it only protrudes about 10 inches past the lift arms.
- Rick
   / Ballast Block
I chamfered the back corner to further help avoid backing into things.
- Rick
2016 Dodge Charger SRT Hellcat Sedan (A50324)
2016 Dodge Charger...
2012 Kenworth W900 (HEAVY DUTY) (A52748)
2012 Kenworth W900...
2014 Dodge Journey SUV (A50324)
2014 Dodge Journey...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2015 Jeep Cherokee Latitude SUV (A50324)
2015 Jeep Cherokee...
