I am not sure about most of you, but when it comes to changing attachments, the one I hate the most is the 3 point hitch PTO post hole digger. Every other implement that I have was either designed or modified to work with my quick hitch. So for me to switch to the post hole digger I have to remove the quick hitch and top cylinder (top & tilt) and then install the digger. I am wondering if anyone has attempted to convert the frame over to a quick hitch compatible setup. The idea that I have is to convert my existing frame to one that looks like the pictured in this link: http://www.harlemanmfg.com/phd75.html
I would add the additional cylinder on top for picking up the auger boom and this would facilitate an added benefit of down pressure. The key would be that that unit would connect to the tractor via the quick hitch thus reducing the time required and the hassle to switch from one attachment to the post hole digger.
