FEL Gin pole (Boom pole and then some)
   / FEL Gin pole (Boom pole and then some) #1
srjones
Columbia County, Oregon, USA
Mahindra 2015HST & Mitsubish R1500
Hello all, this is my first post here, so go easy on me. /forums/images/graemlins/smile.gif
I've been lurking quite a while, but I thought it's probably time for me to post.
I was especially inspired by the postings of RonJHall where he attaches a Speeco quick hitch adapter to his FEL, so the first purchase I made after buying my Mahindra 2015HST was a quick hitch, and then angle iron and pins fabricate it.
I then took a standard farm-store boom pole and made some modifications. First, welding a receiver hitch scope tube to the end and then sliding in a 10' section of stinger tube (the stuff that goes into the receiver). At the end, I drilled a hole for a 3/4" forged eyebolt. At the base is a bracket to mount the 440/880 hoist from HF. Think of it as a large fishing pole. When it's completely raised, it can lift 800 lbs up to 20 feet (in theory, but I haven't tested it yet).
Anyway, comments and questions are welcome and appreciated.
-Steve
   / FEL Gin pole (Boom pole and then some) #2
Your creation looks neat. I am curious about the true lifting capacity once you get 20' up from from the loader attach points. It would seem that a 2000# lift capacity at the attach points might end up being less than 800# once you get 3-6' away on the horizontal axis. This seems like an ideal mini crane to lift trusses/beams on small buildings. Has anyone else used something like this? How much did this cost to build? Is there just one pulley or a block & tackle combo? A couple close up pix would be great
Thanks for the comments. Yeah, I'm very well aware of the limitations. The loader itself is rated for 950 lbs at the pins and the the idea is to keep the tip as near to vertical as I can ( at least 80-85 degrees) If for some reason the pole went into full extension under load, I'd quickly find myself on a rollercoaster ride.
I don't have closeups at the moment, but here's one of me exploring another use for this setup.
   / FEL Gin pole (Boom pole and then some) #4
Based on past posts, I'm thinking of adding a receiver hitch to my FEL bucket. Gives you lots of options.
Mine is much smaller, and it would take a lot of rear ballast to get me to hang on the boom!
Nice for reaching light loads though. I would not trust driving with something hanging way up there, unless it was <1ft off the ground and I'd want my right hand on the FEL. Much too easy to tip over.
I need to trim some trees 20ft up, and making a boom to hold an electric trimmer sounds like the safest way. My fear is what if it get stuck up there............ HowdoI get it down???????
ron
ron
Sorry, I just reread your post and I didn't answer all your questions:
How much? $219 for the Speeco QA + $50 in steel + $100? for the boom pole (can't remember exacltly, I've had it for about 4 years) + $50 for the extention tube + $75 for the HF hoist + $15 for the forged shouldered eyebolt.
Right now it's a single line (and single pully) which is rated at 440 lbs. I might just leave it at that to keep the max load down.
Lifting beams, rafters and wall assemblies is exactly what it's for /forums/images/graemlins/smile.gif
   / FEL Gin pole (Boom pole and then some) #6
Nice project. /forums/images/graemlins/cool.gif
I like your modification using the using the 10' stinger tube. /forums/images/graemlins/wink.gif
   / FEL Gin pole (Boom pole and then some) #7
Wow.. only 950#... That seems low.
My 1 arm loader from the late 1950's has 2500# break out and 1000# lift to full height.
Is it a pump pressure issue.. or weird cyl choce that make the # value so low??
Soundguy
Actually, I was wrong (close, but wrong) Its only 915 lbs.
ML 104 Loader specs
I suspect this has to do the the cylinder size, but other factors could also be at work like you mentioned (pressure, structural steel design, etc.)
Thanks RonH for the encouragement. As I said, you were the inspiration for the Speeco mod. /forums/images/graemlins/smile.gif
Here's a little better picture of some of the specifics with some items labeled:
1. Rather than try spend $18 plus shipping for those hard to find QuickHitch adapter bushings, I made some by welding 1" pipe over the lift pins. Total cost: $4.
2. Standard import (Harbor Freight) 440/880 110v. hoist.
3. That shoelace that keeps coming undone.
4. a short peice of 2" tube welded to a 1/4" plate that's welded to the boom pole frame. A 1" fortified pipe then keeps the hoist on the boom frame.
5. A short peice of flat iron connecting the hoist to the boom to keep the hoist from flopping around when it's not under load.
6. An old rachet winch from a different project. I didn't know any better and I welded it right to the frame. I shouldn't'a done that.
   / FEL Gin pole (Boom pole and then some) #10
You did a lot of neat work there, I like each piece of it.
The whole thing together just frightens the bejibers out of me. There are a lot of little things that can go wrong, & that tractor is going to be laying on it's side, or on it's nose....
--->Paul
HEAVYEQUIPMENT ROLLS OF CONDUIT (A50854)
HEAVYEQUIPMENT...
2014 CATERPILLAR 277D SKID STEER LOADER (A51222)
2014 CATERPILLAR...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
