Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    New Member
    Join Date
    Sep 2005
    Posts
    4
    Saskatchewan, Canada
    Case 830
    Default FEL For Case 830
    Gentlemen:
    This is my first post and need your advice and help. I am about to build a FEL for ths tractor but have been told that it does not have regular frame. This looks to be true so does anyone have any picture of a 1966 Case 830 that show how the frame for the FEL is attched to the tractor. Iam guessing that a sub-frame is built that attches to the rear end assembly and mid point on the tractor, and from here the vertical posts are mounted that support the loader arms. Any advice will be greatly appreciated.
    Thanks
    Derek
  2. #2
    New Member
    Join Date
    Sep 2005
    Posts
    4
    Case 830
    Gentlemen:
    Thanks
    Derek
  3. #3
    Join Date
    Jul 2003
    Posts
    1,969
    Kansas
    2003 BX2200
    Default Re: FEL For Case 830
    Welcome!
    Can't offer specifics on the 830. I suggest you keep your eyes open and when you spot an old tractor with an FEL, get your camera out and snap some pics. A lot of the old tractors had FELs that attached at the rear over the rear axle.
    Ron
  4. #4
    Join Date
    Jul 2003
    Posts
    1,969
    Kansas
    2003 BX2200
    Welcome!
    Ron
  5. #5
    Join Date
    Nov 2002
    Posts
    238
    Pine Bush NY
    Yanmar 1401
    Hi , found this pic that might be helpful. case830
    good luck.
  6. #6
    Join Date
    Nov 2002
    Posts
    238
    Pine Bush NY
    Yanmar 1401
    good luck.
  7. #7
    New Member
    Join Date
    Sep 2005
    Posts
    4
    Case 830
    Thanks for your efforts guys. I have a bit of an idea of what to do now.
    Derek
  8. #8
    New Member
    Join Date
    Sep 2005
    Posts
    4
    Case 830
    Derek
  9. #9
    Gold Member
    Join Date
    Oct 2003
    Posts
    375
    Prosper, TX
    ZD323-60 and JD JX75 currently. Previous: L3800 HST w/ BH77, JD301-A , JD450C Dozer, JD 330, JD F525, Ford 4000, Farmall H
    hotrod45,
    Here is another picture. This is of a Case 990.
    Good Luck,
    Russ
    Attached Images Attached Images
  10. #10
    Gold Member
    Join Date
    Oct 2003
    Posts
    375
    Prosper, TX
    hotrod45,
    Good Luck,
    Russ
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
