07-17-2006, 09:32 AM
#11 (permalink)
| | Super Member
| Re: Creating a simplified Landscape Rake Eddie, one more thought for you. I don't know what size tractor you have, but I the photo show my 6' rake mounted on a Kubuta B2910 (30hp). I also use it on a NH TC24D (24hp). Both of those are small tractors. If you are using it on a tactor larger than 25hp, consider making a bigger rake for your jobs. Quote: |
Originally Posted by EddieWalker My roads are a minimum of 30 feet wide to as much as 50 feet wide. Then there's the debris under the trees that I'd like to clean up. | It strikes me that a 6' rake is small for your roads. If you are running 30hp or more, go up to a 7' or 8 foot rake without hesitation.
Also, I think many people think of a rake as a light duty tool. Please do yourself a favor and don't skrimp on the steel structure. These rakes can be amazingly versitile tools, they can endure a lot of torque stress if you build it heavy enough. Entend your toplink and it can be used to aggressively tear up the soil and it does a great job of smoothing dirt/clay paths, shorten the toplink and you skim across the grass but gather the debris that is in the lawn. I found that a hydraulic toplink makes life easier and makes the rake more useful, but it also taught me that the rake is more useful than I originally thought it would be.
__________________
Snow Trac, the Swedish Snow Tractor, at Wikipedia
Never insult a man with a bag of dog poop in one hand and a tennis racket in the other hand! |
07-18-2006, 12:18 AM
#12 (permalink)
| | Veteran Member
Join Date: Mar 2005 Location: 4000\' mountains of Southern California
| Re: Creating a simplified Landscape Rake Eddie, be careful of how you build your rake. Of course it makes a big difference what your pulling it with. If you are going to be using a little bigger tractor, I suggest that you build it heavy duty. Especially when you will be using it a lot of the time.
I bought a Midwest 8' rake myself and proceeded to twist and bend the channel iron that it was made of into a pretzel.  So I rebuilt it with some heavier metal. I got new channel to hold the tines and welded that to a 4"x7"x 3/8" wall tube. I have had no bending since the rebuild.  Here's a picture of it just after I was done with it, and I had the whole thing powder-coated.
Brian |
07-18-2006, 12:24 AM
#13 (permalink)
| | Super Member
| Re: Creating a simplified Landscape Rake Quote: |
Originally Posted by MtnViewRanch Eddie, be careful of how you build your rake. Of course it makes a big difference what your pulling it with. If you are going to be using a little bigger tractor, I suggest that you build it heavy duty. Especially when you will be using it a lot of the time.
Brian | Brian powder-coating a rake huh, very nice idea. You sure beefed that rake up some. |
07-23-2006, 12:14 AM
#14 (permalink)
| | Veteran Member
| Re: Creating a simplified Landscape Rake Mike, thanks for the comments. It was something that I had to do. Like Bob said, a lot of torque can be applied. I too was amazed at how versatile a landscape rake can be. It just has to be built to take the load that it's given.
Brian |
07-30-2006, 03:44 PM
#15 (permalink)
| | New Member
| Re: Creating a simplified Landscape Rake I made a light rake a few years ago out of some hay rake tines and a piece of 2 X 2 X .25 sq, tubing, and pivets on a 2nd piece of tubing that will slide in to a hitch I have for my tractor. The rake works great for sticks and I even use it to dehatch my lawn and works great for driveway maintenance. Total cost about $50.00. The rake is light duty and does not work good for large stones or logs, but then again the last time I looked I don't have any large stones or logs in my yard or drive way, so I guess it must have gotten them all out.  |
09-06-2006, 11:47 PM
#16 (permalink)
| | Super Member
| Re: Creating a simplified Landscape Rake I picked up some steel today for the rake. One stick of 5X3 angle iron and one flat stick of 3/8X2 for $91. I bought 50 grade five 7/16 inch and a half bolts, nuts, lock washers, a new half inch bit and a pair of pins for $39.
The first picture shows the basic frame.
The second picture shows the hole drilling nightmare I have to deal with.
Eddie |
09-07-2006, 09:56 AM
#17 (permalink)
| | Elite Member
| Re: Creating a simplified Landscape Rake Eddie.....looks like you'll be wanting a Drill Doctor ! |
09-07-2006, 10:39 AM
#18 (permalink)
| | Super Member
| Re: Creating a simplified Landscape Rake I have one, but I'm not very satisfied with it. I still prefer to use the fine wheel on my grinder and eye ball it. I drilled ten holes with the new bit yesterday and plan to drill a minimum of ten holes a day. I hate drilling, but know it won't get done on it's own. hahahaha
25 tines with two holes each means I'll be at it for another four days.
Eddie |
09-07-2006, 11:02 AM
#19 (permalink)
| | Veteran Member
Join Date: Jul 2006 Location: East Bridgewater Massachusetts
| Re: Creating a simplified Landscape Rake Eddy do you draw out a set of plans before you build something or is it all in your head. I tend the draw out my plans and measurements on paper 1st. I'm just curious |
09-07-2006, 11:41 AM
#20 (permalink)
| | Elite Member
Originally Posted by EddieWalker The second picture shows the hole drilling nightmare I have to deal with. | if there ever was a job that needed this tool!
might almost be worth $40 at the local rental center
__________________ Steve - TC33D 4x4 FEL, dual rear remotes with toys |
