HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-07-2006, 02:34 PM   #21 (permalink)
Super Star Member
jinman's Avatar
Default Re: Creating a simplified Landscape Rake
Eddie, I used to know a machinist who went "nuts" the first time he saw me using oil to drill with. He yelled at me to get some cutting fluid instead. I've never forgotten what he said, "Oil is for lubrication and cutting fluid is for cooling." I don't know if he was right, but I have a bottle of cutting fluid I use on anything heavier than sheet metal. I'm always afraid he'll yell at me again.
__________________
Jim
jinman is offline   Reply With Quote
Old 09-07-2006, 02:54 PM   #22 (permalink)
Quote:
Originally Posted by schmism
if there ever was a job that needed this tool!
might almost be worth $40 at the local rental center
Yeah .... thinking back on building my 80" rake I think there was around 80 or so holes .... can't imagine having to drill them without some kind of drill press.
rswyan is offline   Reply With Quote
Old 09-07-2006, 10:02 PM   #23 (permalink)
Member
Hey Mad... can you post a close-up of your gage wheel setup? Especially the up and down adjustment. I need to make one for my BB and for my landscape rake. Yours look very functional. Thanks.
regor66 is offline   Reply With Quote
Old 09-08-2006, 09:13 AM   #24 (permalink)
Super Member
EddieWalker's Avatar
Timber,
I like to draw things out. I'm a constant planner and I realy enjoy figureing out all the details on anything I do before I start. For this, I used my Home Design program and pretend the walls are lengths of steel. It gives me the lengths I know, and then I can easily see the lengths I don't know like the angle pieces.
Then I use it for my materials list for shopping.
Schmism,
A friend back in California has one of those magnet drill press's. He uses it for drilling frames on big rig trucks, and I've been known to borrow it from time to time. Your right, it's exactly what I need, and I think about how much I want one with every hole I drill.
I did my ten holes yesterday, and that was just as painful as I expected. hahaha
Jim,
Thanks for reminding me there is a difference between oil and cutting oil. I'm going to the feed store this morning and I'll see if he has cutting oil. I'd heard the same thing, but forgot all about it.
Eddie
__________________
Link to my Pasture Project http://www.tractorbynet.com/forums/s...81#post1650281
Link to my Deer Blind Project http://www.tractorbynet.com/forums/r...-top-deer.html
Link to video clips of me running my dozer. http://www.tractorbynet.com/forums/r...er-action.html
Link to my thread creating Lake Marabou. http://www.tractorbynet.com/forums/p...ting-lake.html
EddieWalker is offline   Reply With Quote
Old 09-08-2006, 11:52 AM   #25 (permalink)
Timber's Avatar
Send a message via Yahoo to Timber
You can actualy use water in place of cutting oil to keep the metal cool. Just use a little spray bottle
Timber is offline   Reply With Quote
Old 09-08-2006, 10:28 PM   #26 (permalink)
czechsonofagun's Avatar
Send a message via ICQ to czechsonofagun
Cutting fluid is an emulsion of oil and water - at least for steel cutting.
Here is a related article:
Cutting Fluids
Eddie, are you drilling it in one shot or do you predrill first? I have a floor drill press, one of the best tools I ever bought and I would still go in two steps to drill all those holes.
Also the drill press gives you the slow speed you need - unlike hand drill with two preset gear speeds.
__________________
Regards,
Prokop
Engineers like to solve problems. If there are no problems handily available, they will create their own problems.
czechsonofagun is offline   Reply With Quote
Old 09-18-2006, 09:50 PM   #27 (permalink)
Super Member
I rained 3/4 of an inch yesterday and another quarter inch today, so it was a good time to work on my rake.
I had finished drilling the 50 holes awhile ago, to that nightmare is over.
Today I cut some triangles to brace my corners and finished my welding on the flat part of the rake. Then I cut and bent some 3/8 x 2 inch flat stock for the top parts.
I had to figure out the angles and lengths, so I cheated and copied my other impliments to cut down on brain stress.
I even swept the floor and put my welder away!!!
First picture is of the rake on it's edge so I can weld the sides and put in the triangle braces.
Second picture is of one of the triangle braces.
Third picture is of the top mount for the three point attachment. To get the upright pieces lined up, I had to weld in a cross brace. This turned out to be a bit on the high side, so I had to notch it to fit the long pieces together.
Fourth picture is of the rake all welded together. I just have to finish drilling the holes for the three point attachments and then paint.
Eddie
__________________
Old 09-19-2006, 04:38 PM   #28 (permalink)
I'm interested in how it works. Wondering if you miss the angle feature and/or if being so far back is an advantage. Looks pretty good so far.
__________________
Kubota BX23, BT600 BH, LA210 FEL, Maschio L125 tiller, Gearmore BB 20-48 BB, King Cutter 6' rear blade, Homemade PHD, Brinly BST-50 broadcaster, ? 6' cultipacker, log & chain drag.
bx23barry is offline   Reply With Quote
Old 09-20-2006, 10:37 PM   #29 (permalink)
Super Member
It's all together and even painted.
The tines look to have a good space between them, but I'll have to use it to know for sure. They are on 3 inch centers.
I need to finish draging and smoothing around my lake tomorrow, then plant some grass seed. When that's done, I'll put the rake on my little tractor and see if it works.
Eddie
__________________
Old 09-21-2006, 11:26 AM   #30 (permalink)
Looks good. You sure do go through some hydraulic fluid don't you.
Thomas
TxTom is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.30201 seconds with 9 queries
