HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 09-21-2006, 10:16 PM   #31 (permalink)
Nat
Default Re: Creating a simplified Landscape Rake
Eddie, I used mine some today and I'm real impressed with how it windrows the rocks. I found if I angle it, it doesn't throw rocks at me and seems to roll them out a little better. I sorta wish I had gone with the stiffer tines, it would have therefor been a little heavier and would not skip over some of the bigger rocks as it does some of the time. Yours appears heavy enough that it shouldn't be a problem. It looks good to me. Later, Nat
Nat is offline   Reply With Quote
Old 09-23-2006, 07:21 PM   #32 (permalink)
Super Member
EddieWalker's Avatar
Tom,
You noticed my collection of buckets?? hahahaha Yes, the dozer is all hydraulic. One pump for the blade and one for each set of tracks. Three hydraulic pumps and about a mile of hoses!!!! I get one leak fixed and another shows up. The real kicker is that they mostly only leak under load. Just running it parked doesn't show anything. I buy 4 buckets every time I buy 200 gallons of fuel. Sometimes I start to build up on how many buckets I have, but I always have a hose blow and need every bucket I have. Last time it was one of the boom hoses on my backhoe. What a mess. hahaha
Nat,
I have the stiffest tines they sell and as you can see in my pictures, one of them broke. Luckily I don't have much for rocks. I did find some concrete that the tines pulled out and made a mess of.
Eddie
__________________
Link to my Pasture Project http://www.tractorbynet.com/forums/s...81#post1650281
Link to my Deer Blind Project http://www.tractorbynet.com/forums/r...-top-deer.html
Link to video clips of me running my dozer. http://www.tractorbynet.com/forums/r...er-action.html
Link to my thread creating Lake Marabou. http://www.tractorbynet.com/forums/p...ting-lake.html
EddieWalker is offline   Reply With Quote
Old 09-23-2006, 07:36 PM   #33 (permalink)
Super Member
I put the rake on my 35hp Century CUT yesterday and put a few hours on it. Since I've never had a rake before, never used one before and have never seen anybody else use one, it was a bit of a learning experience.
I had to get the angle ajusted just right. Flat didn't give me enough preasure or movement when I went over high spots. The rake would just lift off the ground and dump what I had in it. Too much angle and it was more of a plow then a rake. Just a bit above flat seemed to work the best.
The tines did a fantastic job of collecting sticks. It also doesn't collect dirt, but with the three point hitch pushed all the way down, the tines do dig into the ground niceley. I like that!!! It also thins out the weeds and really does a nice job of preping my dirt. Another nice suprise.
At 3 inch centers, I do loose a few smaller sticks, but nothing I can't live with. What's nice about the spacing is I can really knock down some of the dozer tracks and small windrows the blade makes. Just turning the dozer does a number on the ground, so it's nice to be able to quickly and easily smooth those rough spots over.
The length is nice to reach in under the trees and tough to get to spots, but it doesn't help in any way the amount of material I can collect. It just spills out the sides when it gets full. I'm thinking about putting some sides on it. Not sure how yet, but there are several options.
One problem I had was after about five minutes, a tine busted. It must have been defective because it was the only one to break.
I kept thinking about being able to swivel it and how that would help. For the life of me, I just can't imagine how it would. I pulled it straight and in big circles. I pulled it in figure 8's and sometimes tight circles. It holds everything in it except a little comes out on the inside of the turn. Not much, but enough to tell where the turn was. If I could change the angle, it would have to be done at every turn, and to me that is way more effort than loosing a very small amount of debri. Especially since I can pick up that debri on the next pass.
I'm extremely pleased and suprised at how nice it is to have. It's really turned out to a must have impliment!!!
Thank you to everyone who offered advice, both in this thread and in the older threads I read when researching this project.
First picture is of the rake on the back of my CUT.
Second and third pics are of the rake full of debri.
Fourth pic is my field after I raked it.
Fifth pic is of the busted tine.
Eddie
__________________
Old 09-23-2006, 07:48 PM   #34 (permalink)
Willl's Avatar
Quote:
I look forward to that thread, something with hydraulics would be cool.
__________________
I refuse to participate in any type of recession.
Timothy 2:11-12
My Photobucket
Willl is offline   Reply With Quote
Old 09-24-2006, 12:39 AM   #35 (permalink)
You would be surprised how much more usefull it would be if it did swivel. Anyway it looks awesome and as long as it does what you want it to that's all that matters.
__________________
mudcat is offline   Reply With Quote
Old 09-24-2006, 01:37 AM   #36 (permalink)
Kool! I may have to make something like this.
__________________
Kubota BX23, BT600 BH, LA210 FEL, Maschio L125 tiller, Gearmore BB 20-48 BB, King Cutter 6' rear blade, Homemade PHD, Brinly BST-50 broadcaster, ? 6' cultipacker, log & chain drag.
bx23barry is offline   Reply With Quote
Old 09-24-2006, 08:57 AM   #37 (permalink)
Eddie,
I'm not an engineer or anything, but I think any issues you have with your rake is IT'S TOO CLOSE TO YOUR TRACTOR.
You should take that back to your shop, cut it apart, and lengthen it about six more feet.
Just funning ya. Great looking implement. And if it works for ya, who cares what anyone else thinks!
Ron
RonR is offline   Reply With Quote
Old 09-24-2006, 11:58 AM   #38 (permalink)
Quote:
Yeah, one of the things you could do is set it angled to throw everything to the center - with down and back passes you'd eventually wind up with a windrow in the center, which could be picked up with a loader. Dunno if that would be faster than than just hauling the debris to where you are dumping them or not.
But like mudcat sez, if it's workin' for ya and ya like it that's all that matters.
rswyan is offline   Reply With Quote
Old 09-24-2006, 12:09 PM   #39 (permalink)
Super Member
What I've kind of learned to do is pull the material in a straight line to a place and leave it there. Then I do it again just next to the last pull and leave the pile next to the previous pile. After awhile, I havle a long line of debri all lined up in a straight line.
I first tried to pull the line with the rake, but it all fell out the sides and just made a mess. So now I'm going to try to pick up what I can with the loader and hual that to the burn pile.
It's absolutely amazing at cleaning small areas. But as soon as it gets full, it's effectiveness is drastically reduced. My burn pile is several hundred feet away from where I was working, and as I progress on my land, I'll be even further away, so hauling the piles with the loader might be my best option. I'm just wondering about how much dirt I pick up versus how much material I miss with the bucket.
My guess is I'll get better in time. hahaha
Thanks for the replies,
Eddie
__________________
Old 09-24-2006, 07:06 PM   #40 (permalink)
Nat
Eddie, I also found that once the rake is"full" it's best to "unload". I found that if I angled it and made a couple passes out and back I had a pretty good windrow os rocks and sticks. I would then take my son's Bobcat , sit it at the end of the windrow, then turn it around and push the debris into the bucket, that way I wasn't getting much dirt. I could then carry it and dump it off a terrace. at least you have the backhoe sitting there anyway, I have to wait till he has his Bobcat at home which is mostly on the weekends. A skeleton bucket would be nice for that so I wouldn't have to push the debris into the bucket, I could just scoop it up. I guess we will never have the perfect tool, so we keep on plugging along. Later, Nat
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.33052 seconds with 9 queries
