Results 1 to 9 of 9
  1. #1
    Join Date
    Feb 2006
    Posts
    205
    South Carolina
    Ford 960-5
    Default 3PT trailer mover...
    While taking pictures of my top link today I also got a shot of the trailer mover that I made a couple of weeks ago:
    http://i43.photobucket.com/albums/e3...ctor/hitch.jpg
    Parts in this one are from an engine hoist that I bought from a pawn shop several years ago that was missing the base. Had intended to make the base but bought a new hoist from Harbor Freight for less that the cost to make the base. It is the upright section for the top link. The cross piece is a TSC drawbar with a 1-1/2"X1-1/2" section of 1/4" angle welded to the bottom. A short 2" SQ hitch section to receive the ball mount is welded to the top of the draw bar and the upright is slotted and welded on top of the 2" receiver.
    I'm thinking of taking this one step further and adding an articulated boom using the remaining parts of the hoist. BTW, I gave $50 for the hoist and it had a new 6 ton long reach jack with it.
    Ugly, rusty 1957 Ford 960-5, 5' Bush Hog Squealer cutter, 5' Bush Hog Model 305 HD cutter, 5' King Kutter box blade, & King Kutter boom pole.
    Kanga mini skidsteer, 20hp Honda, standard loader bucket, 4n1 bucket, 12" auger, trencher, pallet forks, and carry-all/leveler attachments.
    Bri-Mar DT508 Dump trailer
    Lincoln AC/DC tombstone
    Ready WelderII 10000ADP
    O/A cutting/welding
    Argon/CO2 shielding gases
  2. #2
    Gold Member
    Join Date
    Nov 2004
    Posts
    299
    granbury tx
    sears suburban
    Default Re: 3PT trailer mover...
    You will get alot of use from that and with added boom even more. I use mine quite often.
    Attached Images Attached Images
    If it can't be altered, it ain't been built.
  3. #3
    Gold Member
    Join Date
    Nov 2004
    Posts
    299
    granbury tx
    sears suburban
    That was the before conversion to 3ph.
  4. #4
    Platinum Member Pooh_Bear's Avatar
    Join Date
    Jan 2005
    Posts
    739
    Dunlap TN 25 miles north of Chattanooga
    Early 1949 Ford 8N
    I could get a lot of use out of being able to move trailers with my tractor.
    I was thinking of drilling a hole in the back of my finish mower to accept a trailer ball (somewhere where the blades wouldn't hit it of course), and also welding a small plate onto the back of my rear dirt scoop to accept a trailer ball. Since 99% of the time I have one of these two implements on my tractor.
    If I had one on the mower it would make it easier to move the little trailers I got when I am mowing.
    Or instead of drilling a hole in the mowing deck I could just weld a bracket on the back of it to accept a trailer ball. That's even better cause it wouldn't catch grass under the deck.
    Pooh Bear
  5. #5
    Join Date
    Feb 2006
    Posts
    205
    South Carolina
    Ford 960-5
    Welding a square tube receiver on my box blade has crossed my mind more than once so that I can tow the dump trailer. Also, I could tow the tractor with trailer hitched to it and kill two birds with one stone. My trailer has a pintle hitch.
    O/A cutting/welding
  6. #6
    Gold Member Adiredneck's Avatar
    Join Date
    Sep 2006
    Posts
    487
    Upstate NY
    2006 Kubota L3400DT, Kubota L5240
    And My version.... I use it to lift logs to skid them out of the woods, move my trailer & my next task.....
    I'm making a ballast "rack" that can be used to haul small loads of wood or concrete blocks while I plow this winter. It will just slide into the receiver.
  7. #7
    Platinum Member herringchoker's Avatar
    Join Date
    Oct 2004
    Posts
    748
    New Brunswick, Canada
    Kubota B7800, Case 450
    Here's my version. I use the 2 outside receivers for a toolbar harrow I made and I plan on building forks, boom pole, etc., etc. to also fit it. The trailer ball (when not being used) stores on a bracket on the forward side of it.
    Kubota B7800, LA402 FEL, Homemade cab, 60" bushcutter, 74" rear snowblower (shrunk to 62").
    Kubota RTV500.
    Case 450 c/w 6-way dozer.
  8. #8
    Join Date
    Feb 2006
    Posts
    205
    South Carolina
    Ford 960-5
    It appears that 3pt trailer movers are one of the easier attatchments to make. Thanks for posting pictures of them as there are features of some that I wished that I had thought about when I built mine. Never too late to modify though.
    Fire up the grinder and welder, I feel a project coming on!!!
    O/A cutting/welding
  9. #9
    Platinum Member roxynoodle's Avatar
    Join Date
    May 2006
    Posts
    989
    NW Ohio
    Yanmar 1510d, 1950 Farmall H
    That is awesome! I am about to make a drawbar for my tractor, and I did have the thought of making a receiver type hitch instead. I'm not sure that's practical to bolt to the bell housing, but I like the one you made for your 3ph.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
