rear weight
   / rear weight #1
hagman
Central, IL
B7610 Kubota
There are probably older threads out there that deal with this question but as a relative "newbie" I haven't seen them. Has anyone made anything that replaces a ballast box on the rear 3 point? You all have much more experience than I do with improvising attachements.
Hagman
   / rear weight #2
Take a barrel, cut holes in the side and insert a drawbar that mounts to the lower arms of you 3-point hitch, find some kind of way to attach your top link to it then fill the barrel with conrete.
   / rear weight #3
I just leave the box blade or tiller on the back.
One less thing to own / store.
Ron
   / rear weight #4
Here is one I built. It has 4 80# bags of cement in it. It fits well in tight spaces where a blade or mower won't.
   / rear weight #5
This is the Ballast drum I made. I don't know what you have for a tractor or what you use it for. This Ballast drum is 800+ pounds. I do a lot of Fork work with my tractor, I palletize everything. Personally I don't use a top link for my Ballast drums and I like them as close to the tractor as possible. I do need to make a lighter drum too and I will cut the top 3rd section off and do it the same way. As long as you draw bar is above center you don't need to use a top link on your drum. My 800 pound drum has a lid and I keep all my chain in the top of the drum
   / rear weight #6
A buddy of mine has an old train wheel he'd intended to modify into a mooring for his boat, but the guy who cut the axles left one side with only about a foot of axle left on it:confused:.
As such the conversion to a mushroom style anchor is more than he wants to go through.
My box blade works great, BUT if it didn't That would be the ultimate low CG counterweight IMHO... I still covet the wheel:eek:... maybe I'll make it anyway...
Lots of great ideas/builds on here... I like yours Timber, but does it ever swing on you?
   / rear weight #7
No I have never had it swing or rock. I keep the turn buckles tight and it cradles in nice between the 3 point arms. When I want to pull something with it I run a cable sling through the eye I have bolt through the draw bar and around the drum. I put a chain through the loops and away I go. The 800 pound wt is perfect and it doesn't make the tractor any bigger so it is easy to maneuver around with the forklift on it
   / rear weight #8
Timber - where are the turnbuckles you speak of and what function do they perform?
   / rear weight #9
The turn buckles are on the lower control arms of the 3 point hitch that keep you implements swinging into your tires
   / rear weight #10
Hagman
Here's mine.
It's an old cattle molassis feed tub, ( free after the cow was done with it ), a spare drawbar bolted tot he bottom of it, a piece of flat stock for a toplink connection, some assorted bolt/nut/washer hardware, and a few bags of concrete mix... minimal cost altogether. Took an hour to assemble... and if i ever ditch it, I remove 2 nuts fromt he bottom and slide my drawbar off...
Soundguy
Terms & Conditions of Auction (Payment Terms) (A59213)
Terms & Conditions...
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
Bucket (A55973)
Bucket (A55973)
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
Portable Restroom (A54865)
Portable Restroom...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
