The shop crane transition
   / The shop crane transition #1
mfrost
CA
JD 750
Was wondering what I could do with my shop crane after the boys left home. This crane is very versitle on the the back of my JD750 with little work. It is totally adjustable especially with my T&T.;) Hope the pictures come through attached.
   / The shop crane transition #2
Nice job. So do you think the drawbar or your lift arms are the weak link? Any counterweight on front to keep wheels on ground?
Thanks. It seems to work better after I painted it JD green;) Have about 90lbs hanging on the front. Think the lift arms would go before the draw bar does. Only try to lift what the 3pt would lift. The top link will lift much more than that but try not to do that so I don't break anything.
This worked great in putting a 1,500lb picnic table together. A real back saver. My wife is my helper and she loves it:D
   / The shop crane transition #4
Wow, nice place, view, tractor, etc. I like the shower addition also (water cooler).
   / The shop crane transition #5
Man that is a boom pole extrordinaire! Nice. I guess that's not your standard walmart picnic table huh?
Will
   / The shop crane transition #6
Did you pour the table yourself, or purchase the pieces?
Nice boom!
David from jax
   / The shop crane transition #7
Nice adaptation of the standard shop crane that's available from many sources.
For any out there who may want to build your own shop crane, or just the parts needed to make the one shown here, How-To-Plans.com has very detailed plans for sale. I bought a copy and plan on doing something based on them even though I have one of the 2 ton shop cranes already.
Nice boom!
David from jax
Got 2 tables at a school auction for $26 plus I had to buy the bolts
Nice boom!
David from jax
Got 2 tables at a school auction for $26 plus I had to buy the bolts to put them together. :rolleyes: They aren't going to blow away.:rolleyes: Only one that bid on them. Guess everyone else thought they were to heavy. It was the excuse I was looking for to retro my crane. Had been thinking about doing that for a while.
Thanks. My wife, JD 750 and I put alot of work into the place and it seems to never end.
I like my cooler holder too. It's out of the way and easy to get to especially when it gets to 115 degrees.;)
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
ADS Bulk Seed Buggy (A59814)
ADS Bulk Seed...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
