I finally finished my winch mount. Still waiting for winter to set into Maine. There is not much frost in the ground and we have had enough rain to make the ground to soft for the land owner to let me on to start cutting. I did hook it up and pulled my pickup around a little. It is going to work great.
As far as the hydraulic pressures are concerned. I have found that the winch works fine and when it loads up to a stall, the relief valve will open and I definately know when that happens. Engine speed does affect the speed of the winch. The winch is a two speed winch as well.
I feel this is a good alternative for a small tractor compared to a logging winch at $2500plus. I have a B7500 Kubota(21hp@engine,17hp@PTO). I have about $1100 into this project and that does include the new winch. I would have had some more if I had to buy all the steel, but I cleaned out some of my scrap pile for this.
The only thing different I would do is to use square stock instead of the channel iron.
A good sand blasting and paint will happen this coming sommer as I do not have a heated garage and wifey would shoot me if I did it in the cellar and stink up the house.
Can't wait to really try it.
