Results 1 to 10 of 10
  1. #1
    Join Date
    Jan 2002
    Posts
    823
    Tidewater VA.
    Ford '92 2120
    Default 3rd Function FEL remote loader switch
    Hey Gang,
    I wanted to build an electrical control switch for a 3rd function hydraulic valve for use with my FEL grapple. I needed to mount it on my loader joystick but did not want a rocker switch type. I also wanted the ability to stack two or three at a time. This is what I came up with.
    The unit is made out of 1x1 steel tubing with a pie slice cut out of it and folded together and then welded.
    Next, I added a ½” split shaft collar in order to mount it to the loader stick. The ends are standard plastic capplugs for sq tubing with ribs. They are amazingly snug and secure.
    The push button switches are IP67 rated for dust proof and waterproof. I placed heat shrink tubing over the solder lugs after soldering the wires so even if the end caps leak a little moisture the inside is waterproof anyway.
    The metal housing is bead blasted, zinc plated inside and out, and then chromated for corrosion resistance in a tractor type environment.
    Belden PVC cable runs from the switch box to a relay pack for power switching and interlocking. The connections are soldered and covered in heat shrink with outside covering being marine grade adhesive lined.
    The relays provide the switching logic in order to allow only one valve spool to be active at one time regardless of whether both buttons are pushed.
    Here is the unit installed on the tractor.
    So tell me what you think. What kind of improvements you would suggest or other uses. Do you think it will hold up on a tractor?
    Steve...
    "My biggest fear is that when I'm gone my wife will sell all my tractor gear for what I said I paid for it. "
  2. #2
    Super Star Member kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    11,089
    Westminster, MD
    John Deere 4110
    Default Re: 3rd Function FEL remote loader switch
    Excellent!
    That should hold up real well, and sure is cheaper than the $170.00 handle I just bought from JD for my joystick!
    John Deere 4110HST
    FEL, MMM, FEL Forks (homemade),I-Match, Ballast Box, #380 plow (modified to fit), Markham LD-48 Grapple, Trac-Vac 854 and lots of other STUFF.
    John Deere 4x2 Turf Gator
    View some of my projects/adventures in my Picasa Album
    Simple JDParts Tutorial HERE
  3. #3
    Elite Member
    Join Date
    Feb 2002
    Posts
    3,368
    western,pa.
    John Deere 850/Kioti DK 35 with top and tilt, kl1450 fel with quick detach bucket
    Well done..
    Very nice work !!
    Vince,
    Kioti DK 35/Rhino 85 backhoe
    John Deere 850 72" MMM
    Hustler Fastrak 54"
  4. #4
    Bronze Member frenchie4x4's Avatar
    Join Date
    Dec 2006
    Posts
    88
    Pa.
    DK50c
    Unbelievably NICE !! great pics. Very well done. How is it working so far? One more thing you have got way to much free time on hand .Anyways I like it. frenchie4x4.
  5. #5
    Veteran Member BTDT's Avatar
    Join Date
    Sep 2006
    Posts
    2,208
    North Texas
    IH M Farmall-propane powered, H Farmall (father-in-laws), Ford 1300 diesel
    Nice job. Does it seem awkward to use with the buttons down from the knob like that. Looks like if it had been placed where the knob is would be more comfortable to use (like a T handle shifter). If I remember correctly, Case 580D backhoe/loaders had a clutch disconnect button on the loader raise/lower lever so you could speed up engine while working bucket without having to try to keep tractor from running over whatever was in front of you.
    Praise is not something you do to get closer to God, praise is a response to God being close to you.
  6. #6
    Join Date
    Jan 2002
    Posts
    823
    Tidewater VA.
    Ford '92 2120
    Thanks for the complements guys. I still need to hook up the hydraulic lines so I have only tested it electrically. The valve spools do energize.
    BT I tried several positions but I have long fingers and like the buttons low. The split collar lets me twist or move it up or down anyway.
    Attached Images Attached Images
    Steve...
  7. #7
    Super Member mjncad's Avatar
    Join Date
    Aug 2006
    Posts
    5,107
    Front Range of Colorado
    JD 4200 C.U.T. & JD 130L Lawn tractor
    Nice work! I like seeing projects that look as good as they function.
    My 24/7/365 menu for GITMO: Bacon for breakfast, a ham sandwich for lunch, and a pork chop for dinner.
    Stuff I've made for the JD4200 or done with it are at this link.
    http://picasaweb.google.com/mjncad
  8. #8
    Super Member 3RRL's Avatar
    Join Date
    Oct 2005
    Posts
    6,807
    Foothills of the Giant Sequoia's, California
    55HP 4WD KAMA 554 and 4 x 4 Jinma 284
    Very very first class job. That looks store bought man!
    Nice "out of the box" thinking on your part. Your photos came out great too.
    Thanks for sharing it with us.
    Rob-
    ...The Older I get...the Better I Used to be...
    Member of the Month
  9. #9
    Join Date
    Jan 2002
    Posts
    823
    Tidewater VA.
    Ford '92 2120
    Thanks for the complements. Thought I'd set one up to go on the BH wobble stick next. My friend up the road wanted one so I built several.
    Steve...
  10. #10
    Silver Member TobyH's Avatar
    Join Date
    Sep 2004
    Posts
    109
    Vestal, NY
    Kubota BX2200
    Is that a left handed joystick mounted on the right side?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
