HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 02-08-2007, 10:45 PM   #1 (permalink)
Default FEL quick attachment ideas
I have a Simplicity Legacy XL FEL loader rated for 500lbs.. I am looking to fab a quick attach system that will mount to the loader arms and tilt cylinders with minimal weight and forward extension of the implement. I am building adjustable forks and would like to be able to switch between my bucket and forks with nothing more than sliding in a pin.
I already realize that the Legacy (Kwikway) bucket brackets probably will need to be modified, but I would like help in designing a simple (I'm guessing male) bracket attached to the loader, that would mate with an appropriate (again, I'm assuming female) bracket welded to an attachment such as the forks I am trying to fabricate. I don't want skid steer stuff as the attachment system itself weighs too much. I have looked at the Deere attachments, which are great, but I am still looking for something that might work equally well with less weight. Lightweight hook and pin setup. Any pictures and descriptions would be great! Thanks
Dave
ddonnell is offline   Reply With Quote
Old 02-09-2007, 07:49 AM   #2 (permalink)
Elite Member
kennyd's Avatar
Default Re: FEL quick attachment ideas
Sounds like a great project, any may here could help but are probably unfamiliar with your FEL and tractor. Could you post some pictures?
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
kennyd is offline   Reply With Quote
Old 02-09-2007, 09:15 AM   #3 (permalink)
Here are a couple of pics of the loader. Pretty standard 2 cylinder setup.
Old 02-09-2007, 10:34 AM   #4 (permalink)
Gold Member
I did a set for a Kubota B2400HSD (700# capacity) a few years ago that only extend the implement a couple of inches. They probably weigh 50#, but I think they could have been lighter. I will take a picture next week and post it.
Farmerford is online now   Reply With Quote
Old 02-20-2007, 09:42 AM   #5 (permalink)
I am building my quick attachments for my loader and am now at a decision point. I am going to use a hook system to slide under and catch the top pins of the implement (see first picture). However, I'd like some input from those of you that use the Deere type attach as to any advantages to its lower linkage method (picture 2) as versus a horizontal tab and pin design (picture 1). My thanks to Kubotatrax for his ingenious design and pictures (his design is picture 1).
Old 02-20-2007, 09:54 AM   #6 (permalink)
Elite Member
kennyd's Avatar
I think either system will serve you well. I use the Deere QA system but from the pictures it looks like the other style would do just as good.
__________________
JD 4110HST
Old 02-20-2007, 10:53 AM   #7 (permalink)
GT2
Have you seen this? eBay: Quick Attach PLAN (14 pages) for Front End Loader (item 180086921778 end time Feb-24-07 06:53:30 PST)
GT2 is offline   Reply With Quote
Old 02-20-2007, 11:07 AM   #8 (permalink)
GT2,
Yes I did see that and it looks like it would work also. The only problem is that it would require that I modify the bucket's existing brackets which I'd like to avoid. The direction I'm headed lets me use the existing bucket brackets and adjust the QA to fit them so that some possible future owner could go back to the OEM hookup if they wanted to. I'm also building a fork attachment which I can set up to mate with my new QA, and any future attachments I might dream up would be designed to fit my homemade tractor QA also.
Thanks, Dave
Old 02-20-2007, 11:36 AM   #9 (permalink)
Elite Member
MrJimi's Avatar
Why would anyone pay for plans? most members here willingly share their ideas, I do
Jim
__________________
Click here for my current weather
Case 1845C with dirt bucket, forks, 3 point quick hitch on the front, 30'. boom, 6 & 1/2 foot disc harrow, 5 foot Howse RC, root and tree bucket and Grouser tracks and a Ford F-550 pick up,7.3 Turbo with Auto and a Crosley 25' X 8'.6" X 14 K D/O trailer.
PDF files don't like me !!
Making a F-550 Pick Up thread
My Gallery
My other Gallery
Revielle video here
Dear Eliot
MrJimi is offline   Reply With Quote
Old 02-20-2007, 12:32 PM   #10 (permalink)
Quote:
The disadvantage to method one - you need two fasteners (pin and keeper)
The disadvantage to method two- more fabrication time for mounts and attachment mounting points.
Personal opinion- from the pic's. Kubotatrax has the winning design, maybe add a coarse threaded weld-on nut to the inside edge (unless it's there and we can't "see" it.), then weld a wing to a coarse thread bolt (like a thumb bolt)for the retaining pin, that way only one pin to lose and no tools required.
tlbuser is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
