HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Build-It Yourself
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 02-24-2007, 08:11 AM   #11 (permalink)
Elite Member
Tractors4u's Avatar
Send a message via Skype™ to Tractors4u
Default Re: yet another custom backhoe subframe
Excellent work. I have a Deere 4310 and a Koyker 3 point backhoe. That is one of the first projects I want to tackle when I get home from Iraq later this year. I don't do any real heavy work with mine, but I want it to be sturdier and easier to attach. Yours looks great.
__________________
Brent Pepper
Tractors4u is offline   Reply With Quote
Old 02-24-2007, 11:56 PM   #12 (permalink)
dfkrug's Avatar
Quote:
Originally Posted by montejw
The thumb caught my eye. I'll have to look at it more, but I think I see how it works. Got any pictures of the bucket extended?
I forgot your 2nd question, Monte. Since I can't easily post a video,
I took 4 pix in series from full open to full closed. They are posted in
the thread I started about my articulated thumb:
http://www.tractorbynet.com/forums/b...umb-fixed.html
__________________
See my TBN projects at:
http://mysite.verizon.net/resyfcgt/
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Diesel fuel dispenser
Bucket dentistry
custom hydraulic b/h thumb
adapting a 4-in-1 bkt to my Kioti
JD 4300 rebuild (new!)
dfkrug is offline   Reply With Quote
Old 02-24-2007, 11:59 PM   #13 (permalink)
dfkrug's Avatar
Quote:
Originally Posted by design
Has anyone contemplated mounting a "quick hitch" cat 2 bracket to a custom sub-frame (attached at the rear axle, and the loader mounting plates.)
With the quick hitch, I think it may be possible to then use a 3 pt. hitch frame on the back hoe. The frame whould carry the top link loads to the sides into the subframe.
I am not following your idea. What is a "quick hitch cat 2 bracket"?
Thx for the kudos, guys.
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 02-25-2007, 02:14 AM   #14 (permalink)
Gold Member
I think he's talking about one of these, welded to a sub frame instead of mounted to the 3 point hitch.
Saw the pictures of the thumb, great idea.
Monte
montejw is offline   Reply With Quote
Old 02-26-2007, 09:27 PM   #15 (permalink)
montejw,
Thank you for finding the photo. That is the idea. Weld this quick attach hitch to a subframe. The idea of 3 point BH scares me into thinking about other ways to quickly mount/dismount a backhoe.
Design
__________________
God is in the business of caring for people:
EZE 36:26
M5400
7' RB, 7' rake, Bradco 609 waiting for seat time...
New Hampshire
design is offline   Reply With Quote
Old 02-26-2007, 09:37 PM   #16 (permalink)
dfkrug's Avatar
That could work. It would be better than a standard 3-pt hitch
with the exception of the toplink. All the upper stresses would
still be on one point.
I do think you could make a good attachment out of this "quick
hitch" if you weld it on and provide TWO attachment points at the
top for the hoe, and support the top of the "quick hitch" at more
than just the toplink bracket on the tractor.
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 02-27-2007, 11:02 AM   #17 (permalink)
dfkrug,
I would like to weld this adapter to a subframe (much like the current 4 point systems) I would not attach the back of the quick hitch to the top link area on the rear of the tractor, instead I would weld the upper corners of the qucik hitch to bar stock running down to a subframe. I will try an draw something today.
Design
__________________
EZE 36:26
M5400
New Hampshire
Old 02-27-2007, 02:38 PM   #18 (permalink)
dfkrug's Avatar
Design:
Sounds like your plan would work. If the quick hitch makes your
job any easier, then it makes sense. I see these things at HF
Tools for $69.
Don't forget to post some pix.
__________________
Kubota B21 rebuild
1 cy FEL bucket
custom b/h thumb
custom b/h subframe
Bucket dentistry
Old 02-27-2007, 03:04 PM   #19 (permalink)
These pix are the results. There is no detectable wiggle or flex, I
am happy to report.
Looks great. I got a good chuckle out of the subliminal message
tlbuser is offline   Reply With Quote
Old 02-28-2007, 02:55 PM   #20 (permalink)
Super Member
3RRL's Avatar
Very nice work Dave.
Looks like you went the extra mile on this one. It's really heavy duty with the use of all that thick steel. Seems to me it would weigh quite a bit more than 200lbs though. I'll bet if you weigh it on a scale, it's gonna be over that. But that's part of what makes it so sturdy. I like your mounting position so close to the hoe too, and you don't have to take off the lower lift arms either.
Great project man,
__________________
Rob-
...The Older I get...the Better I Used to be...
3RRL is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.25215 seconds with 9 queries
