Page 1 of 2 12 LastLast
Results 1 to 10 of 17
  1. #1
    Silver Member gcp's Avatar
    Join Date
    Mar 2007
    Posts
    242
    Default Fabing a platform
    Guys, Iím thinking of building a steel carrying platform of sort, and bolt it onto the front of my YM2000. It will allow me to carry things around (rocks, sacks of cement, lumberÖ), and will add the needed weight to the front. Any construction ideas you care to share will be appreciated.
    gcp
  2. #2
    Gold Member
    Join Date
    Jun 2006
    Posts
    320
    South of Seattle
    Dad's=JD4440;IH1066;JD4020;JD3010;2 JD"B" 1949 & 1937(hand-crank)
    Default Re: Fabing a platform
    I have seen pictures of "rock boxes" that farmers use and they have either a hinged bottom floor with a locking mechanism/handle for dumping or the front vertical plate is hinged and can be folded down to push the rocks out the front. This might be something to consider when you built yours.
  3. #3
    Silver Member oldhippy's Avatar
    Join Date
    Sep 2004
    Posts
    238
    mo
    junk
    I built a front bumper that had a 2" reciever in the middle of it. Then all you had to do was a put whatever you wanted on the front. I mounted a sprayer to spray round-up. Also had a shackle on the front to hook chain in and pull thing with. A friend of my filled his bumper like mine with lead that he got at a tire store for weight (he had a steep hill to bush hog up). I just installed a front end loader and had to remove it and will miss it. I have a Yanmar. dan
  4. #4
    Join Date
    Sep 2004
    Posts
    238
    mo
    junk
    Here is a picture of the bumper on tractor.
    Attached Images Attached Images
  5. #5
    Join Date
    Jul 2003
    Posts
    1,935
    Central VA, USA
    Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
    old hippy: That a WD or WD-45 in the background?? Looks pretty straight...what's wrong with it?? BobG in VA
  6. #6
    Join Date
    Sep 2004
    Posts
    238
    mo
    junk
    Bob that is a 1953 WD that belonged to my father-in-law. It is a pretty nice tractor. It is not used for much, a little trailer pulling and such. thanks big dan
  7. #7
    Join Date
    Mar 2007
    Posts
    242
    Thanks to oldhipp, I've now made my Yanmar even more versatile. The receiver he sent me worked out like a charm...after I had to drill a couple of holes on my tractor's bumper, which proved a not so easy task with the hand drill. But it's done and over with, now I can tow a trailer, or use the platform to haul stuff around. A big thanks to Big Dan!
    gcp
  8. #8
    Veteran Member crbr's Avatar
    Join Date
    Apr 2007
    Posts
    1,688
    East TN
    Kub - 2K6, B7800
    Quote Originally Posted by oldhippy
    A very pretty barn in the background. Thanks for the pic.
    ** Kubota **
    Psalms 86
    John 1:12-13
    Duraflap / Kaydenco not worth a hoot for service or products.
    "Google" is a proper noun, not a verb.
    If you mean what you say, then say what you mean, or just don't say anything
  9. #9
    Join Date
    Mar 2007
    Posts
    242
    crbr, where did you see my barn?
    gcp
  10. #10
    Elite Member sandman2234's Avatar
    Join Date
    Dec 2005
    Posts
    4,558
    Jacksonville, Florida
    JD2555 and a few Allis Chalmers and now one Kubota
    I think he was talking about Oldhippy's barn, right behind the other tractor.
    David from jax
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
