Results 1 to 9 of 9
  1. #1
    Silver Member John D's Avatar
    Join Date
    Nov 2006
    Posts
    143
    Johnson co. TX.
    JD 5103
    Default Old spreader use
    I was given this spreader and it was in bad shape. I took it apart and had to torch the gearbox off the funnel. got to thinking I realy dont need a spreader so I thinking useing the frame for a wht box. a 55 gal drum fits it OK but Im going to have to add some things to make it work. Im useing a JD I-match and it doesnt fit so Im thinking cut the tubeing on the top and adding in something to match the top hook on the I-match. Im open for any ideas. jb
    Attached Images Attached Images
  2. #2
    Join Date
    Nov 2006
    Posts
    143
    Johnson co. TX.
    JD 5103
    Default Re: Old spreader use
    As it goes.
  3. #3
    Join Date
    Nov 2006
    Posts
    143
    Johnson co. TX.
    JD 5103
    As it goes 2
  4. #4
    Join Date
    Nov 2006
    Posts
    143
    Johnson co. TX.
    JD 5103
    And so on
  5. #5
    Join Date
    Nov 2006
    Posts
    143
    Johnson co. TX.
    JD 5103
    And on some more
  6. #6
    Join Date
    Nov 2006
    Posts
    143
    Johnson co. TX.
    JD 5103
    Last one
  7. #7
    Veteran Member joes_427_vette's Avatar
    Join Date
    Aug 2004
    Posts
    1,243
    Midwest
    New Holland TC 55 DA, 4110 John Deere, HT 20 Bolens, 1456 Bolens
    I have been trying to buy a spreader like that at farm auctions. They go for 3-4 hundred ( all beat up for a hundred less than new ). They sure bring a buck around here.
  8. #8
    Join Date
    Aug 2004
    Posts
    1,944
    Caldwell Co. NC
    2006 Kama554; 92 Belarus 250AS
    If you use a plastic drum you can fill it with water. Add a pump and it doubles as a sprayer. Clean up the base and add a platform to hold the drum(s) or take them off and use as a carry all.
    Fertilizer really tears them up if it's not cleaned off and especially if some is left in it but it looks like it was salvageable. On the other hand, the "price" was right and if you have a better use for the components go for it.
    2006 Kama 554, 92 Belarus 250AS, Bombardier Outlander Max 400.
  9. #9
    Join Date
    May 2005
    Posts
    1,119
    Eastern WA
    Jinma JM354
    I know, I know. Every time I'm desperately looking for a implement used and finely give up and go buy new someone always pops up with I just scrapped out one of those. If he did need a spreader though Agri-Supply advertises replacement poly funnels for those. The ad didn't say what the cost was though. I've pretty much resigned to new implements now cause the last used good deal I got cost me in dollars and time as much as going and buying new. Live and Learn I guess. bjr
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
