Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
  1. #21
    JCB
    Guest
    Default Re: 90 Amp wire feed welder vs. 1/4" steel ?
    When I took a welding class a while back we had a licoln 130 we could use. It was a pretty nice unit: small torch, manuverable...it felt like you had a pencil in your hand compared to the hammer size torch on the bigger units.
    It was a nice unit, but I ended up getting a MM250. Great machine! I think one of the limitations you'll run into with a smaller unit on "trailer repair" is the quality of the steel you're welding and inability to prep it (clean, bevel, etc.) for that little unit.
    If you're really going to weld rusty 1/4" material, I think you'd be much, much happier in the 140-150 range.
    Joe
  2. #22
    Join Date
    May 2005
    Posts
    977
    Joe,did you ever hear of a grinder? I've heard it all here,you recommend he get a bigger machine so's he can weld on rust? that takes first prize so far,,next contestant,,,,thingy
  3. #23
    Bronze Member jarokoro's Avatar
    Join Date
    Nov 2006
    Posts
    52
    Mid-Missouri Area
    John Deere 990
    I looked one up 120/90 the specs says it welds up to 1/4 inch flux core only. I have a HOBART 140 Handler and have always used flux core I have no problems with heavy stuff.
    E-Z MIG 90 AMP FLUX 100 WELDER
    Rob
    JD 990 w/300CX FEL, Woods BB60, Auger,JD Blade, Rock Rake, Load Trail GN Dump, 20' GN Trl, JD 8A Backhoe and other Misc Toys
    I reject your reality and substitute my own! Adam Savage of MythBusters
  4. #24
    Join Date
    Jul 2005
    Posts
    1,924
    NH seacoast & Coos County
    Kioti DK45S
    [quote=crbr]Hard core welder.
    I can bet you never flinch when a piece of slag pops and jumps down your collar... Not a flinch.... quote]
    ..or when a little ball of sizzling slag rolls down your ear canal !!!!! MikeD74T
  5. #25
    Platinum Member bobodu's Avatar
    Join Date
    Mar 2004
    Posts
    954
    Whitley County,In.EIEIO
    Farmnought.Gravely Model L,Gravely Model LI,1941 Clinton two wheeler
    Quote Originally Posted by MikeD74T
    Oh YEAH!!! Ear wax fires......scares the bejesus outta anyone dumb enough to watch me weld...
    1945 Allis-Chalmers,1967 Wheelhorse.The wife has a bubble hooded Simplicity and a Dixon.
    Anything green here- has roots or gets spent!!!
  6. #26
    Bronze Member turnerbend's Avatar
    Join Date
    May 2006
    Posts
    96
    Rome, Ga.
    Yanmar 1500
    I have a lincoln 220 stick welder and a 90 amp wire welder. The linclon haven't been plugged in in over 2 years. The small wire welder do a real good job on welding broken tiller tines ..........
  7. #27
    Join Date
    Jul 2004
    Posts
    236
    Escondido California
    2005 Ingersoll Rand Bl370b
    I got some info from the hobart site about arc welding and mig welding hope this helps
    Attached Files Attached Files
  8. #28
    Elite Member
    Join Date
    Oct 2003
    Posts
    3,629
    the Steernbos (Holland)
    Zetor 3011, Zetor 5718
    1/4" is about 6 millimeter ?
    I run a 180 amp mig welder on 400V 2 phase. It's a well known brand, with copper spools, and it has more guts than the leaflet promised. I still wish we bought a 250 amp 3 phase welder, because it sometimes lacks penetration hot rolled material with the typical carbon skin.
    When i imagine welding with half the power i have now, i guess i had to grind everything down to shiny mirror like appearance to get some penetration, make multiple passes and move the torch so slow that it would be an achievement on its own to get an equal weld.
    If you want to renovate trailers, get a stick welder. Allways penetration, and cheap power. You are going to regret wasting your money on a 90 amp unless the only thing you do is weld automobile tinwork.
  9. #29
    Join Date
    May 2005
    Posts
    1,119
    Eastern WA
    Jinma JM354
    I agree, for dirty poor fit-up get in an' get'r done work, get a stick welder. bjr
  10. #30
    Veteran Member MJPetersen's Avatar
    Join Date
    Feb 2007
    Posts
    1,255
    Warsaw, Poland
    YM 1510-D
    Renze,
    1/4 is a tiny bit more than 6. 6.35 mm is more acurate.
    Mike in Warsaw
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
