chris.miller
- Joined
- Jun 3, 2008
- Messages
- 7
I'm looking at getting a tractor for the natural resources department of a town on Cape Cod, MA. Initial task will be to clear out underbrush in forested areas to reduce fuel loads and ladder fuels as part of our wildfire management plan. We'll also use it to pull tree trunks etc. out of the woods to create burn piles, trail maintenance, etc. I do not expect to be cutting lawns, and won't be grading roads or keeping road right of ways clear; the DPW has some larger equipment dedicated for that type of work. DPW's larger equipment is simply too large for this type of work.
We have several larger parcels (one around 800 acres, several in the hundred acre size). We're also maintaining some areas as field habitat with once or twice annual mowing to reduce woody brush. We have a couple backpack mounted cutters (like a blade on a large weekwacker) as well as chain saws and other hand tools.
I've got around $25,000, give or take a bit. We qualify for a municipal discount of about 20% off list on Deere, New Holland, and Kubota, and I think some of the vendors also carry accessories such as Woods decks. I'm thinking of a 4wd tractor, probably manual trans, a rear PTO rotary cutting deck (for brush), FEL, (and possibly a trailer to move it, although I could get by for a while with a loaner trailer until I can raise more budget $$). Would a flail work better than the rotary cutting deck? I'll be in second growth underbrush, including vines, poison ivy, bull briar, etc. for much of the work.
I plan to maintain the tractor myself; I'm an ASE certified master mechanic and the DPW can also help; hoping to get something we can use for 20 years.
I currently have an older JD 260 lawn tractor of my own and I'm happy with its ruggedness and how it's lasted. Have a friend with a smaller Kubota and I've been impressed with it as well. Have no experience with the New Holland tractors.
Any suggested combos? Should I maximize the HP and wait on the FEL for a year or so? Is a medium duty rotary deck strong enough for brush clearing?
Thanks for any suggestions. Chris
