#11 (permalink) | |
Quote:
I am a true fan of Allis tractors. My day had two a 1951 CA and 1956 WD-45. We farmed a 170 acres dairy farm with them and a 1950 something John Deere A. The picture of the WD is the first time I have every seen a single front wheel. Wonder if this is origional? Don
__________________
Country Life Beats Working. Less than 5 years to Retirement |
#12 (permalink) |
I have a Ford 861 gas and its a good old tractor and my neighbor has a 961 gas with narrow front end which is also a good old tractor but at the end of the day my little Jinma 284 4 wheel drive will do more work and out pull both. The only advantage I can see with my 861 is a little more pto HP but will not pull half of what my 4 wheel drive diesel tractor will.
But hey, they are a lot of fun. Chris |
#13 (permalink) | |
Quote:
#14 (permalink) |
Allis Chalmers models C & CA were also available with single front wheels.
__________________
'04 Mahindra 4110, FEL w/quick attach bucket, 509 Backhoe, Markham tooth bar '52 Allis-Chalmers CA w/ A-C 2 bottom plow |
#15 (permalink) |
I installed a 3-point conversion kit on my WD a couple months ago. Search under projects, there are pics. I bought the kit from Allis Chalmers Parts. 3 point hitches, new and used parts. Adaptors manifolds, and wheels/rims for Allis Chalmers. 3pt 3 pt hitches manifolds and wheels for Allis Chalmers.. Shipped, it was about $360. It installed in about 2 hours, but that's because I took my time and didn't really know what pieces went where. There were no directions. If I had to do another, it would easily be less than a half hour to install.
For 1200 bucks, I would buy that 3 wheel WD in a heartbeat.
__________________
Knowing is not enough, you must apply. Willing is not enough, you must do. Bruce Lee |
#17 (permalink) |
Most of the Allis tractors up until the late 60's were offered with the single front tire. I have seen a WD, D17, and 185 with it. (185 might have been retrofitted)
__________________
Charlie |
#18 (permalink) | |
Super Star Member
NAA is nice.. but I'd tep up to a ford 660 or 661.. that way you get live pto AND live hyds.. plus hyds jump from 2.89gpm to 4.0 gpm when you hit the hundred series. 661 might have ps too. Naa and the 6XX use the 134ci engine and will get you in that 30ish hp range. 8XX is similar but jumps you into the 48-52 hp range.. which is more than you stated... though prices for good 6xx / 8xx will be virtually identical.
My advice would be to find the 660 / 661 or 860/861 gassers.. or the 861 diesel. The 861D will have a 172ci diesel that has great parts availability. The 661D has a 144ci diesel that is a bit spendy to get parts for. the *4* are 4spd, non live pto.. the *5* are 5 speeds non live pto.. the *6* are live pto.. the *71 and *81 are SOS ( 10 spd power shift ) models and i would avoid them like the plauge if you want a worker. ( now if you want a parade queen, and find a good running sos. that's different. ) I have a 660, and an 850 both with loaders and I move round hay bales with them.. good workers.. easy to work on, when needed. soundguy Quote:
#20 (permalink) | |
Super Star Member
Quote:
still.. it's worth looking.. again.. though.. I'd try for the live pto.. IE.. I'd take a 861D over a 3000 any day if the 3000 didn't have the live pto.. soundguy |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
