I agree that some folks are not up to date terminology wise and create confusion when communicating with those of us who are.
So are our trucks really just front wheel assist? I don't think so.
When you engage 4wd you power all the wheels, in many cases in CUT's, mechanically. Whether or not there is sufficient traction to prevent wheel slip at some particular HP output is another matter. So limited slip or not in the rear and like wise in the front is not really the issue just as tire size is irrelevant.
CUT's are intended for extended periods of 4wd as needed and determined by the operator as are pickups. It is, at best, inconsistent to call a truck with a transfer case and a drive shaft that can power the front differential a 4wd truck if the same, nearly the same, or equivalent mechanical configuration on a tractor is not 4wd WITH NO EQUIVOCATION.
I have no problem with the technologically out of date folks using their antiquated terminology. Shucks, I have to be careful to not say ice box and other anachronistic terms. My problem is with those who insist that those of us trained on new technology and terminology are wrong, misguided, or at best marginally tolerated. If a finer distinction is needed to differentiate between styles of achieving 4wd then that too is another issue but so far has not been a hindrance in communications.
Pat
To try to clarify this just a little bit more - the reason that there is a significant distinction between true four wheel drive tractors (the big articulated dudes) and our four wheel drive tractors (that we can switch in and out) has to do with our sales are recorded and reported. I believe that, at least according to some reporting schedules, the tractors that have MFWA, MFWD, or are otherwise known as 4wd actually fall into the 2wd category for the sake of that poll. You could kind of think of it like this - our little tractors are part time 4wd (possibly like your trucks) as opposed to the real 4wd tractors that are full-time 4wd.
Try not to be too hard on folks that aren't up to speed on new vs. old terminology. Whether or not someone calls your tractor 4wd or front wheel assist or happy yankee flypaper has very little to do with its abilities. I refer to my little front wheel assist and mechanical front wheel drive tractors as four wheel drive in casual conversation as well.
Take care.
