Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Nov 2008
    Posts
    2
    Sanford, NC (for now)
    IH 574 circa 1974
    Default IH 574 or 574 Util?
    I inherited an IH 574 and would like to get a FEL for it. I see different model loaders listed for IH 574 and 574 Util. I presume the 574 is a row crop tractor and believe I have a Util ... but how do I know for sure? Thanks!
  2. #2
    Gold Member
    Join Date
    Apr 2008
    Posts
    498
    WI
    TYM T353 HST / TX3500 Loader
    Default Re: IH 574 or 574 Util?
    Quote Originally Posted by Rock Creek View Post
    Check this link for info about your tractor. They only show one model here, but...
    TractorData.com International Harvester 574 tractor dimensions information
    I'm sure that there are IH enthusiasts here who can help more.
    Good Luck
    Lunk
    TYM T353 HST w/TX3500 Loader / Faver SCX526LT Grapple / Woods BB60X Rotary Mower / Bush Hog SBX65 Box-Blade / JI & S 6' Snow Bucket
  3. #3
    Platinum Member Heywood Jannockitov's Avatar
    Join Date
    Jan 2008
    Posts
    841
    Near Schomberg, Ontario Canada, the equestrian center of the universe
    Deere 27d, JD 5425 cab, JD F620, JD XUV 850D, Case 580 SE, IH 484
    Welcome Rock Creek!
    I have a IH 454 that is virtually identical except with a 3cyl. diesel, about 42 hp. I found a good used tractor that never had a loader on it, so the front end was still good. I had a new Frey loader put on it.
    That was 22 years ago. I suspect the only difference between row crop and util. on this tractor is the front axle. Swept-back on the util. and straight on the row crop, but I may be mistaken. Mine has the swept-back front axle.
    The different axle geometry would have an impact on what loader will fit I would imagine.
    If you put a new loader on this 574, do a trans-hydraulic fluid + filter change so that you arent running dirty old hydraulic oil through the brand-new loader valves and cylinders.
    Attached Thumbnails Attached Thumbnails IH 574 or 574 Util?-img_1370x-jpg
    Definition of "Horse": A 4 legged mammal looking for an inconvenient place and expensive way to die.
  4. #4
    Join Date
    Nov 2008
    Posts
    110
    NH
    1962 IH 606, JD 2440, JD 5410, MF 265, MF 271XE, 58 Case 420 Shovel dozer
    I know a few people with 574s. You can run most of the IH loaders on it.
    A friend of mine has an IH 1250 on his, and the 2000 loader on my 606 would fit also.
  5. #5
    Member
    Join Date
    Oct 2005
    Posts
    46
    Rock,check your private messages
  6. #6
    New Member
    Join Date
    Nov 2008
    Posts
    2
    IH 574 circa 1974
    Mseriesfreak, check yours ... I responded. Tks.
  7. #7
    New Member
    Join Date
    Feb 2010
    Posts
    2
    I have a Koyker loader on mine and very satisfied.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
