Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1
    Join Date
    Sep 2002
    Posts
    1,026
    Ohio
    Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5525
    Default 85 to 100 hp tractor suggestions
    Looking for a good 85 to 100 pto hp tractor with cab. Use would be to run baler and possibly mower, and moving 4x5 hay bales around. Something with easy forward reverse transition set up. Cab need air and heat. Any suggestions?
    Slippy
  2. #2
    Join Date
    Jun 2003
    Posts
    1,649
    Northern, New York
    Kubota L3830 03: RTV 900
    Default Re: 85 to 100 hp tractor suggestions
    Kubota, JD, there are just to many to list all.
    M-5040 w/cab, 05 RTV 900, Where the maple sap flows
  3. #3
    Elite Member WilliamBos's Avatar
    Join Date
    May 2004
    Posts
    3,795
    Innisfil, Ontario, Canada
    MF 1635 12x12 Powershuttle
    Quote Originally Posted by Deerlope View Post
    MF, AGCO, Buhler, CNH
    Thanks,
    Will
    I do not care if someone's net nanny is watching!! You need to stop...
  4. #4
    Join Date
    Sep 2002
    Posts
    1,026
    Ohio
    Thank you. Yes I am aware of all the manufactures, but I was looking for a little more detailed response such as the particular model and maybe someone has run a hay operation and used various tractors and has found one to be more user friendly and reliable when doing this type of work. The tractor I use now has a shuttle shift lever that is mechanical and clutch. A full day of moving hay is tuff.
    Thank you again.
    Slippy
  5. #5
    Join Date
    May 2004
    Posts
    3,795
    Quote Originally Posted by Slippy View Post
    Thank you again.
    OK, have a look at the MF 5400 series with the Dyna -4 transmission.
    MF 5400 Series
    Thanks,
    Will
  6. #6
    Join Date
    Oct 2008
    Posts
    111
    Smarr Georgia
    L5030 cab, JD 2940
    We use a JD 2940, good tractor for baling and dragging the 15' batwing around. Easy to work on if the need arises and it will. Have some neighbors with the 6K and 7K series JD's and they have to go back to the dealer for any little cough or sneeze.
  7. #7
    Gold Member
    Join Date
    Dec 2006
    Posts
    429
    Oakdale, TN
    Kubota M8540HD ROPS
    Are you sure you need 85 - 100 PTO HP? There are a lot of nice tractors out there that can handle 4x5 bales that have 80, 85, 90, or 95 engine HP but come in under 85 PTO HP.
    Hydraulic/power shuttle transmissions will eliminate the need to clutch when going between F/N/R, some fancier setups also have a two speed power shift or a full power shift with no clutching required.
  8. #8
    Super Member Farmwithjunk's Avatar
    Join Date
    Aug 2005
    Posts
    7,514
    Mt Washington, Kentucky
    Where do I begin.....
    I've got a couple I sure wouldn't hesitate to recommend.
    First is a 6430 JD. 95HP and loaded with features. Definately a fine ride. Not cheap by any stretch.
    Second is a Massey Ferguson 583. 85hp, and a real bargain. Well equipped and IMHO, the best buy in it's HP class on todays market.
    There are three kinds of men;
    1.) The ones that learn by reading
    2.) The few who learn by observation
    3.) The rest of them have to pee on the electric fence for themselves.
  9. #9
    Join Date
    May 2004
    Posts
    3,795
    Quote Originally Posted by Farmwithjunk View Post
    Not to jack this poor guy's thread, but it sounds like the 583 has worked out well for you. How many hours on it Bill? Have you had any problems like some folks had with the early 400 series??
    Thanks,
    Will
  10. #10
    Join Date
    Jun 2003
    Posts
    1,649
    Northern, New York
    check out the M-8540 and the M9540 Kubota here Kubota Tractor Corporation Web Site
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
