GreenWannabe
I haven't really seen it talked about much here, so I will add my two cents worth. The wheels for most R-1 Ag tires have a number of different positions in which they may be mounted. Filled R-1s mounted in their widest positions will give you the most stability for any given tractor. The lower the tractor is to the ground, the better, as well. Good luck in your search.
