I am also looking at the Bobcat CT225/230. I'm not sure where in Canada you are but I am only 2 hours from Niagara Falls and my local dealer has really good prices right now and they are comparable to the ones you mention. Kioti can't touch the Bobcat tractors currently because both are offering free FEL's but Bobcat's rebate is nearly triple depending on the model so I don't know how much I would look into that brand if overall cost is a major factor.
As I'm sure you know, the Bobcat tractor (not implements though) is 99.5% the same as a Kioti, made in the same factory on the same assembly line. The main difference is the that Kioti uses their own loaders and backhoes whereas Bobcat uses Rhino brand loaders and backhoes. Depending on who you believe (comparing Kioti vs. Bobcat vs. Rhino spec sheets), the Kioti loader/BH has better specs compared to the Rhino but both have significantly more capacity than anything in the BX series.
I don't own either tractor and do not have any seat time in either but my research agrees with most of the opinions above. The BX is a great all around machine that can do some incredible things based on its size. However, the size is also it's limiting factor. The FEL has a capacity closer to 500lbs vs. 1000lbs on the Bobcat and there is minimal ground clearance, especially with a MMM attached. The BX series seem to be made with mowing in mind but can handle a variety of attachments. The Bobcat is a tractor that is designed to be used with various attachments, all of which would be bigger than what a BX could handle (72" rear finish mower, 60" tiller, etc.)
Here's a breakdown of the advertised prices (before tax):
CT122 with FEL, turf tires, and no Mid PTO for $10,675
CT225 with FEL, industrial tires and no Mid PTO for $10,595
CT225 with FEL, industrial tires, Mid PTO, one set of rear remotes for $11,495
CT230 with FEL, industrial tires and no Mid PTO for $11,899
CT230 with FEL, industrial tires, Mid PTO, one set of rear remotes for $12,388
54" MM mower $2395 (this is list price most likely could be negotiated)
72" rear finish mower $2495 (list price also)
If you go with a Landpride rear finish mower and King Cutter tiller you could save close to another $1000 compared to list prices for the Bobcat units.
