Hello,
I am faced with my first purchase of a tractor/mower and would like to ask for your opinions. Here is my situation:
- 25 acres of rolling ground with slopes (5 to 15%, with only a couple of areas a bit steeper to a maximum 20%)
- I will need to mow almost monthly during the season, in order to mechanically control aggressive blackberry shoots (the blackberry was set back with a Gyro Trac GT 25 and new shoots will need to be mowed as soon as they get to be about a foot high, and this will be repeated until the blackberry root system will be exhausted)
- I assume I'll be out there at least 5 hours at a time, 5 times a season, for the next 5+ years
- this season the entire 25 acres are an open field, but starting next season there will be rows of plants spaced about 13 feet apart
I should also add that I am mechanically-impaired, so I would prefer to deal with simpler systems and with those under warranty (which means that I'll have to buy new equipment). Thank you for any suggestions you might be able to offer.
Dan
Portland, Oregon
