Search Forums For:
 HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Buying/Pricing/Comparisons
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-25-2009, 05:04 PM   #1 (permalink)
Default 2 range hydro vs 3 range hydro
I have only ever owned a 2 range Case garaden tractor. What advantages does a tractor have with 3 ranges for the same HP around 30 or so?
KC
__________________
Getting Close to a purchase
kcook is offline   Reply With Quote
Old 10-25-2009, 05:15 PM   #2 (permalink)
ChuckinNH's Avatar
Default Re: 2 range hydro vs 3 range hydro
You won't see much difference in the high range between a tractor with a 2 range transmission, or a 3 range. The low range in a three range transmission is quite a bit lower than in a two range, and allows more torque for the real grunt jobs, but little transport speed. Medium range is kind of like the upper part of the low range in a two range transmission, and perhaps will allow somewhat higher transport speeds. I have done some loader work with the medium range in mine, but low range works better. I wouldn't really be afraid of either one now that I have used both as long as the tractor you are using has enough torque to do the things you want in low. I think most complaints about the two range transmissions come from folks that want to mow faster than low range will allow, while the high range doesn't produce the torque they need for mowing hilly areas.
__________________
B2620,Loaded R-4's , Wallenstein BX42 chipper, Bush Hog SQ148 RC, 4' x 8' chain harrow, Simplicity Legacy with 48"mmm, turbo collector, Country Line carry all, Countryline Middlebuster, Woods 48" BB, Kubota QA for loader, Kubota forks, and more to come...
ChuckinNH is offline   Reply With Quote
Old 10-25-2009, 07:37 PM   #3 (permalink)
whistlepig's Avatar
I can't comment on a two range hydro since I have never used one. My B7800 is three range. I use low for brush hogging and loader work, medium for mowing my yard and working around the house. High is used for road gear. I do a some driving on the road but not a lot. I could get by with just low and medium range. High range is nice to have when it's needed.
whistlepig is offline   Reply With Quote
Old 10-25-2009, 08:31 PM   #4 (permalink)
Having owned a Case tractor with the two range transmission, you will notice a huge difference with any other tractor! On my Case, the low range was too slow for mowing, and the high was good for nothing except for high speed road travel. Remeber, that Case has a hydraulic transmission, not a hydrostatic.
My BX had a 2 range transmission, and my B has a three range transmission. I use low for loader work, medium for mowing, and high for transport.
Will
Will_C is offline   Reply With Quote
Old 10-25-2009, 09:58 PM   #5 (permalink)
Elite Member
Builder's Avatar
Quote:
KC
High is mostly only useful for road transport. You find it on larger tractors that are taken out along roadsides.
__________________
'00 New Holland LB115 4x4 Backhoe: 108HP, Powershift. Cab-AC, 4WD/4WS, posi front/rear axles, 4in1 FEL, X-hoe, Aux hammer hydraulics, Gannon compactor & buckets.
'05 AGCO/Challenger MT285B 4x4 CUT: 48HP HST, Cab-AC, 4in1 q/a FEL w/ aux hyd, 90" Landpride Power Rake, 8' Meyer P/A snowplow, Herd spreader.
'07 GMC 3500 SRW 4x4 Crewcab SLT: Dmax/Ally, utility body
'92 IH 4800 4x4 Dumptruck: DTA-466 at 250HP, airbrakes, 7 sp w/OD, Fabco front axle & transfer case, airbrakes, 12' dump, 33K/56K GCWR.
Builder is offline   Reply With Quote
Old 10-26-2009, 03:05 AM   #6 (permalink)
Super Member
IslandTractor's Avatar
Mowing is where the third range comes in most handy. As others have stated, the low range is for grunt work and the high range for road travel. The two speed HSTs have the same basic high and low gears as the three range transmissions but lack the important middle range. I'd not own another 2 range HST now that I have had both.
IslandTractor is offline   Reply With Quote
Old 10-26-2009, 07:18 AM   #7 (permalink)
lawn_king's Avatar
Kubotas hst + is a 3 range with high low in each range, a six speed hydro.
__________________
Grand L 3540 HSTC, 724 FEL and lots of other stuff.
lawn_king is offline   Reply With Quote
Old 10-26-2009, 01:18 PM   #8 (permalink)
Gold Member
I have owned both (first 2 range) now 3 and I much prefer the 3 range. As medium is what I use the most.
__________________
Kubota 2620, Loaded R4's, FEL, 4' Bush Hog box blade, 5' Bush Hog landscape rake. Toro Timecutter Z 5060 ZTR 50"deck
Charlton John is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.18261 seconds with 8 queries
