Results 21 to 30 of 33
02-27-2010, 01:34 PM #21Super Member
- Join Date
- Aug 2009
- Posts
- 5,277
- Location
- Beaver Creek, Northern Michigan
- Tractor
- Kubota B2320
Re: What tractor to buy?
Just my opinion, but Kubota, John deere, etc equals parts availability. Some of the others, like an older Bolens, are getting difficult to locate parts. Keep that in mind. You are going to find a ton of tractors for sale in that $3-4000 range. You have to actually go see them, drive them, talk to the owner and make a decision. No one can say from behind a computer screen if any particular machine is "good" or "bad" other than generalizations based on history, parts availability, or general reputation.
BP
"Some chickens, some gardens and a Kubota."
02-27-2010, 01:36 PM #22Super Star Member
- Join Date
- Jan 2007
- Posts
- 12,462
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
The plow is nice but that is a lot of money for a lawn mower sized tractor with not so great parts support.
I would really consider a 8N. Tons of them, cheap, and can do a lot of work.
Where are you located? I know where there is a Cub Low Boy and a Jinma 284 with a Loader for the cheap.
Chris
02-27-2010, 01:38 PM #23New Member
- Join Date
- Feb 2010
- Posts
- 19
- Location
- Maryland
- Tractor
- Kubota L185
Yeah, the parts availability scares me on something that's been out of production so long. It was in really great shape and drove perfectly so I thought it might be worth it. My buddy was convinced it was worth no more than approx. $2200 so I passed. Since the mid atlantic was hit so hard with snow it seems anything with a blade was for sale or for sale at an inflated price.
02-27-2010, 01:39 PM #24New Member
- Join Date
- Feb 2010
- Posts
- 19
- Location
- Maryland
- Tractor
- Kubota L185
02-27-2010, 01:43 PM #25
02-27-2010, 01:54 PM #26
P.S. Joey...Bolens parts are not that hard to find...Jack's Small Engines can get pretty much anything you would need for the Bolens...If it is as good as you described, it's definitely worth consideration...just don't expect to find parts readily available locally...have to go the order online and wait route.
02-27-2010, 02:17 PM #27
Try [email]sheafstractor@grics.net. He says he can get any part (including manuals) within a couple of days...I think that particular model has an Iseki (Japenese) engine...they have a pretty good track record. It's the same brand of engine used in the current MF GC series.
02-27-2010, 02:27 PM #28Super Member
- Join Date
- Jun 2005
- Posts
- 5,684
- Location
- Northern California-Tehama Co.
- Tractor
- 2008 Mahindra 5525, 1964 MF-135 diesel, 1951 Farmall Super A, 1951 Minneapolis Moline BF, 1945 Oliver 60 Row Crop, 1949 JD B widefront
Neat looking little tractor. Looks similar to my Bolens GT1453 that has a 14 hp Tecumseh gas engine.
I found this one on craigslist for $600 including a 42" mid-mount mower and the 32" wide rototiller. Maybe you could find a similar rototiller to fit that G152.
The asking price is within your budget. You may be able to haggle the price down a little to say $3K.
02-27-2010, 03:37 PM #29Veteran Member
- Join Date
- Oct 2007
- Posts
- 2,411
- Location
- Mid Atlantic
- Tractor
- Kioti CK25 Shuttle Shift, loaded tires
I saw that Bolens too on CL. Seems nice. But, I also thin it's a little high. You can find a JD 400 series similarly equipped for about that kind of money, and I think it would be a better buy. Now if you could get him to say $2500 or so, then it might make some sense.
There are a couple of nice 455's right now on ebay, worth checking out.
At $4K, you will be limited to quality GTs or a much older tractor. However, the GT's won't have the weight nor hydraulics to do any heavy lifting/towing.
Did you see the Kubota with a broken drive shaft for $2700 on CL? Might be a better choice. Just have to understand how much work and money is involved with the broken drive shaft.
Just remember if you want a loader later on, they aren't so easy to find used, and aren't a whole lot cheaper than new when you do. Another word of caution: the JD 400 series with AWS option cannot be fitted with a loader.
02-27-2010, 05:01 PM #30Veteran Member
- Join Date
- Jun 2005
- Posts
- 1,929
- Location
- MD
- Tractor
- Kubota L3940 L5030 MF205-4
Welcome to TBN. I bought my 1st tractor at an auction, with spring coming (I hope), you will start to see more auctions around. As someone else recommended, Jacks small engines is good for parts for garden tractors, etc. They are located in MD but I order on the web from them.
L3940HSTC, QA FEL, BH92
L5030HST,QA,FEL
MF 205-4
Husqvarna YTH24V48LS (the other orange)
KK Finish Mower, KK Tiller, 6' rotary mower, Pallet forks, PHD, Blade, Carryall, cultivator, 2 wheel barrows, assorted gardening tools,
Similar Threads
What implements do I need and where to buy them?
By Browns329 in forum AttachmentsReplies: 6Last Post: 07-20-2009, 10:25 PM -
What's the next mower to buy?
By biffo in forum AttachmentsReplies: 6Last Post: 03-16-2009, 08:30 PM -
To buy new Kubota now, or not to buy now?
By Richie46 in forum Kubota Buying/PricingReplies: 3Last Post: 03-05-2007, 05:32 PM
