Results 1 to 10 of 10
  1. #1
    Join Date
    Mar 2007
    Posts
    206
    Phoenixville, PA
    Cat 262c, NH TN75, JD 6430 premium, JD 5325, Kubota BX2200, Ford 1710HC, JD 333E, JD3720, Farmall 504, Farmall 404.
    Default 563 or 673 Loader for John Deere 6430 premium?
    I have a 6430 premium and would like to get a loader for it. From what I have seen, the 673 loader only offers an additional couple hundred pounds of lift capacity over the 563. Does anyone recommend getting the 673 rather than the 563?
    The loader will be used for a variety of different tasks including moving round bales and moving material (dirt, gravel etc).
    thanks
  2. #2
    Gold Member stravis's Avatar
    Join Date
    Apr 2009
    Posts
    258
    Henderson, GA
    2009 John Deere 5101E Limited
    Default Re: 563 or 673 Loader for John Deere 6430 premium?
    I haven't used either of those models, but I do have a 553 on my 5101E. I use mine for the same tasks that you list there. My round bales are 1600# and I've put down enough gravel to pave 1500 lf of driveway. The capacity is more than I need. I've yet to find any task that even requires the engine to be at more than idle speed. If I had to make a complaint, it would be that the loader speed could be improved, but I am used to backhoe loaders. My flow is 22.5 gpm and yours is 29 gpm, I believe, so your speed should be an improvement over mine.
    My opinion, the 563 is all you need.
  3. #3
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Without seeing these loaders up close and personal I would advise you to consider the strength of the two loaders in question. A 6430 can develop a lot of force against the loader, I would buy the better built or heavier of the two. Hope you can see both to help you decide since ag loaders are not as heavily built as construction loaders.
  4. #4
    Join Date
    Sep 2002
    Posts
    697
    Alachua, Florida
    JD 790, JD 6420
    I have the 6420 with the 673 Loader and I like this very much. But, be careful because you can lift a lot weight very high and things can get a bit shaky if you aren't careful!
    Leo
  5. #5
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,803
    South West MI
    John Deere 2030, John Deere 6415
    My vote is the 673 mechanical self leveling loader. I have a JD 6415 with a 640 SL loader. If it did not have a loader, that's what I would get.
    The 640 SL loader is rated (at 31.5" forward of the bucket pivot point):
    3968lb at full height
    4630lbs at 1.5 m (59")
    5575lbs at ground level (breakout force)
    Bucket Rollback Force (at 31.5" forward of the bucket pivot point)
    4744lbs at full height
    5575lbs at 1.5m (59")
    4946lbs at ground level
    Not sure what the 563 or 673 specs are, but the 673 is what replaced the 640.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  6. #6
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Hope the OP has a loader by now this thread is from 2010.
  7. #7
    Join Date
    Aug 2010
    Posts
    3,803
    South West MI
    Quote Originally Posted by jenkinsph View Post
    Goes to show I don't read the original post date, thanks.
    I would be nice if the blue band at the top of the posts change color to red when a post is over a year old
  8. #8
    Platinum Member econometrics's Avatar
    Join Date
    Jan 2013
    Posts
    689
    East Texas
    Deere 5075E MFWD OOS w/PR, 540E; Gator 825i
    Quote Originally Posted by Zebrafive View Post
    I am guilty of doing this, too guys. Doh!
    Hey OP, what did you get?!
  9. #9
    Join Date
    Mar 2007
    Posts
    206
    Phoenixville, PA
    Quote Originally Posted by econometrics View Post
    673 (heavier duty unit). 563 or 673 Loader for John Deere 6430 premium?-photo-jpg563 or 673 Loader for John Deere 6430 premium?-photo2-jpg
  10. #10
    Join Date
    Jan 2013
    Posts
    689
    East Texas
    Default
    Quote Originally Posted by candersen10 View Post
    673 (heavier duty unit). <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=344332"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=344333"/>
    Sweet set up!
Similar Threads
  1. Grading 3x20 & loader mount Deere blade
    By tomd999 in forum John Deere Owning/Operating
    Last Post: 02-19-2009, 03:40 PM
  2. 110
    By joecdeere in forum John Deere Buying/Pricing
    Last Post: 05-08-2002, 09:34 PM
  3. Replies: 92
    Last Post: 08-21-2001, 11:14 AM
  4. John Deere, how did you make my tractor?
    By JohnMiller3 in forum John Deere Owning/Operating
    Last Post: 07-29-2001, 04:23 PM
  5. BROKEN DEERE 4200 & 420 loader
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 07-26-2001, 10:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
