Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Apr 2010
    Posts
    2
    Default Need help with tractor size
    Hi there,
    We have a small farm and are looking to buy a good used tractor with a loader, pto, and 3 point hitch. We want to be able to make hay (run a mower, tedder, etc.) and clip pastures. Ideally we would eventually like to carry round bales with it. We have both used tractors before but I am unsure what HP is recommended for this kind of activity/weight.
    Any advice? Would be grateful for any suggestions as to models/brands as well as size.
    Thanks,
    Lucy
    p.s. our land is somewhat hilly and we are in VT so there's snow 1/2 the year!
    Last edited by illuci; 04-21-2010 at 02:42 PM. Reason: remembered other important fact
  2. #2
    Join Date
    Aug 2005
    Posts
    1,491
    Guernsey Co. Ohio
    Ford 3000, JD 2550
    Default Re: Need help with tractor size
    The size of the bales would really be your determining factor. Everything you list could easily be done with a 40 hp tractor, maybe smaller, except maybe running a round baler. Someone correct me if I’m wrong, but I think you’ll want at least 50 hp or larger for most round balers, especially in hilly terrain.
  3. #3
    Elite Member
    Join Date
    Sep 2009
    Posts
    4,749
    Murray, KY
    1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
    50 HP range makes good small farm tractors because of the weight/power balance. Our 60 HP 265 MF is just a tad too heavy/large to be truly handy but 10 HP too much is much better than being short 10 HP when it is REQUIRED.
  4. #4
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,402
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    Quote Originally Posted by illuci View Post
    Hi there,
    Thanks,
    Lucy
    I have a 2008 Mahindra 5525 for handing haying chores on my 10 acres. 54 hp engine, 45 hp pto, 2WD, gear tranny, power steering. It has the ML250 FEL (6-ft wide bucket, 2950 lb lift to 10.5 ft height) which would handle 1000-1500 lb round bales pretty well. I mow with a 6-ft Hawkline brush hog (rotary mower). The tractor with FEL weighs about 6500 lb with loaded rear tires.
    Need help with tractor size-dscf0051-small-jpg
    Need help with tractor size-dscf0061-small-jpg
    Need help with tractor size-dscf0062-small-jpg
    The small tractor is a 2005 kubota B7510HST (21 hp engine, 17 hp pto) that I traded for the 5525. Paid about $18K for the tractor and FEL, $1100 for the mower (new prices). You should be able to find something 5-10 years old that would be more in the $10K range.
  5. #5
    Super Star Member TripleR's Avatar
    Join Date
    Mar 2009
    Posts
    18,919
    Missouri
    Kubota M8540HDC, L5740HSTC, BX2200, BX2660, John Deere 425&1025R, Case, Massey Ferguson, Ford
    I have farmed with smaller/less horsepower, but I really wouldn't want to use anything in the under 50 HP; not saying it can't be done, just sure wouldn't want to.
    Clothes make the man; naked people have little or no influence on society - - Mark Twain
  6. #6
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    I agree.. making hay... I'd go no lower than 50hp. the extra weight and size will help making round bale moving safer too.
    might even shoot for 60engine hp.. so you can have 50 at the pto for the haybaler.
    soundguy
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
