Page 1 of 2 12 LastLast
Results 1 to 10 of 15
  1. #1
    Member
    Join Date
    Apr 2010
    Posts
    25
    Default 18-25hp tractor less than $3500 with attachements? Your suggestions
    I have a small subdivision lot. Backyard is 125' wide and 500' long roughly 1.5 acres. Mostly field with a few planted or selected trees left. Previous pasture land so it's fairly flat. Empty lots on both sides so I tend to cut 20-30' over on those lots to keep the briars away.
    Goal is to smooth out bumps and keep back brush. So I need box scrape and bushhog / good mower deck. Once I get the land butter smooth I'll switch to a quallty mower for a clean cut look.
    3500 is my price cap unless it had a bucket or back hoe attachment.
    Alis chalmers B with plow,disc, scrape and mower deck is nearby for 1900. Those lack 3 point hitch but can be adapted. Other models ive seen were
    yanmars and Mitsubishi diesels and a few ford 1100 diesels. But I get a kick out of the old looking model b allis chalmers.
    Any tips of a solid tractor model?
  2. #2
    Join Date
    Aug 2005
    Posts
    1,020
    Guernsey Co. Ohio
    Ford 3000
    Default Re: 18-25hp tractor less than $3500 with attachements? Your suggestions
    At that price you're at the mercy of what you can find for sale. Alot of 8N and 9N tractors around here, but we don't know where you are. Before buying, make sure it works for what you need to do. Also, understrand that it's not "if" something needs fixed, but when.
  3. #3
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    JD 4300, JD X485 JD 4x2 Gator, JD 425, JD455
    I'd go get a JD 425 with a 54" deck. Start off with something that will handle the mowing job easily, even if it gets up to a foot or more tall. This tractor will handle the rough and tumble, and be in your price range.
    If the humps are in need of trimming such that the mower deck hangs up, then rent a skidsteer with blade, or Harley Rake, or whatever for a couple hundred and take care of them. A one time thing.
    Do this only if it satisfies your itch for a tractor.
  4. #4
    Member
    Join Date
    Apr 2010
    Posts
    25
    8n and 9n are a bit more than I need. Breakdowns is a factor so I wanted to stick with simple solid proven models that parts can be found for. I do have an itch for a "kewl" old tractor.
  5. #5
    Gold Member rmully's Avatar
    Join Date
    Sep 2007
    Posts
    386
    North Carolina
    YM 2020
    I had a wonderful Ford 600 that was easy to work on... you could get one in good shape for 3500.
    Experience is what you have left after you have lost everything.
  6. #6
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,124
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    try to find a ford hundred series .. ie.. 640, 650, 660 or 840, 850, 860 or those same in the **1 models. 6** are baout 33hp, while 8** are about 45hp. *4* models are 4spd, *5* models are 5spd, *6* models are 5spd with live pto via 2 stage clutch. **0 means 55-57 year model, and **1 means 58-62 year model.
    depending on your area, you should be able to get an average 'hundred' series plus a 5' hog and a box blade for your 3500$ number. If not.. shoot for a NAA.. pretty much a 640 with the cruder rear axle design of an 8N.. and an early crude hyd setup similar to the hundred series. NAA and up had live hyds.
    in the end, for what you want to do.. even an 9n, 2n, or 8n will do what you want. shoudl be able to get one of those and mower and blade easilly for your 3500$ budget and have $$ left over. 8n is more desireable than the 9/2n due to 4spd trans, both brakes on left, and position control hyds.. however all 33 ae otherwise nearly equal in capabilities. don't pass on a 9n/2n that is otherwise a good deal just to get the 8n hyds if it's a close call for alot more $$.. a 30$ set of limiter chains will let your 9n/2n mower just like an 8n with a lil finess.
    I'd for sure get a unit with 3pt lift. and while that B allis is cute.. I think you might want the extra hp and weight the slightly larger n will give you.. again.. look for a hundred series preferably. I'd take an average running and working 00/01 with blade and mower for 3500$ over a good 8n with blade and mower for 2500$
  7. #7
    Super Star Member Egon's Avatar
    Join Date
    Aug 2001
    Posts
    16,631
    Nova Scotia, Canada
    That Allis B with a plow, disc and a drag of some type will be perfectly suitable for the work you describe. It'll do everything you need to get the land nice and smooth.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  8. #8
    Super Star Member
    Join Date
    Aug 2001
    Posts
    11,474
    Upper Midwest USA
    Quote Originally Posted by renter damaged uhoh View Post
    Puzzled now.
    If 8N is more than you need, and breakdowns are a factor that you don't want....then I don't know what to say.
    They don't come any simpler or solid than the 8n Fords. IMO (and I am JD through and through).
  9. #9
    Join Date
    Mar 2002
    Posts
    42,124
    Central florida
    and you will find parts for the old fords probably more plentifull than just about any other machine. just looking at a farm store like TSC.. probably 3/4 of the tractor parts they carry are for fords. Tons of ford parts thru napa, and if you have part numbers, lotsa ford parts are available at yer local ford CAR dealer parts counter. points.. many bearings.. etc..
    soundguy
  10. #10
    Super Member
    Join Date
    Apr 2000
    Posts
    5,586
    Cedartown, Ga and N. Ga mountains
    1998 Kubota B21, 2005 Kubota L39
    Given the criteria and budget, I would bring someone in to regrade and seed the lot. Then use a residential mower to keep it up. Much easier to transport and once "butter smooth" easier to mow with.
    MarkV
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
