I'm trying to decide between the following four "compact", gear-driven tractors:
2010 JD 3005 4WD 27.5 HP 2000 lb ($12,200)
2010 JD 4005 4WD 40 HP 3200 lb ($16,950)
2010 NH T1510 4WD 30 HP 2385 lb ($11,500)
2010 Bobcat CT335SST 4WD 38 HP 3668 lb ($12,900)
Dealers:
4 JD dealers within 20-44 minutes drive of my house
2 NH dealers within 30-75 minutes drive
2 Bobcat dealers within 30-75 minutes drive
Concerns:
Bobcat is new to the tractor biz.
The Bobcat is built by Kioti.
I don't have a Kioti dealer within 100 miles.
The Bobcat and JD 4005 are 1000 lb heavier: will I have to wait until the ground is completely hard to mow? I don't want turf tires... would like to be able to plow snow.
Intended use:
Smoothing and mowing 9 acres.
Tilling large garden.
800' of gravel drive to maintain and plow.
Add a loader some day.
Property:
I live in KS: my property is flat pasture and there are no trees or rocks to clear. My property has a max 12' per 500' elevation change. Should I consider a 2WD JD 3005 ($10,000)? My neighbor managed to plow his gravel drive with an ancient 2WD tractor with chains last year.
Thanks for your thoughts!
Chris
Dealers:
Concerns:
Intended use:
Property:
Chris
