Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Gold Member
    Join Date
    Apr 2002
    Posts
    316
    Peabody, Ma.
    KUBOTA BX-22
    Default Re: Implement sheds?
    Paint it black and it looks like a stealth fighter. [img]/w3tcompact/icons/laugh.gif[/img][img]/w3tcompact/icons/laugh.gif[/img][img]/w3tcompact/icons/laugh.gif[/img]
  2. #12
    Gold Member
    Join Date
    May 2002
    Posts
    381
    Near Buffalo, NY
    Kubota GL3430 HST
    I built a 16' x 16' "pole barn style" shed. The floor is 3/4" pressure treated plywood. I believe it is the best floor because:
    1 it stays dry
    2 it's smooth and flat
    3 won't rot
    4 easy to clean
    5 easy to work on equipment
    6 easy on the knees & back
    7 holds heavy machinery (using 2 x 6's for joists)
  3. #13
    New Member
    Join Date
    Sep 2005
    Posts
    0
    <font color=blue>Paint it black and it looks like a stealth fighter. </font color=blue>
    Funny thing is that was my exact thought as I looked at my "masterpiece" while taking the photos...[img]/w3tcompact/icons/smile.gif[/img]
    Bill
  4. #14
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,719
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Ok, here is a pic of a structure I made for my finish mower and other small odds an ends, after the 8N took its spot in the barn.
    Soundguy
    Attached Images Attached Images
  5. #15
    Join Date
    Mar 2002
    Posts
    52,719
    Central florida
    another view of that shed
    soundguy
  6. #16
    Join Date
    Mar 2002
    Posts
    52,719
    Central florida
    And here is the reason I had to build that shed in the first place... as there -used- to be room in the barn for the finish mower, .... but I added a mini horse, and the old 8N.
    Soundguy
  7. #17
    Join Date
    Oct 2001
    Posts
    2,219
    Montana (Near Bozeman)
    Former Owner PowerTrac 425 (September 2003)
    Are the joists at 16 center? Do you have any trouble with oil on the plywood? Can you show some pictures?
    PJ
  8. #18
    Join Date
    Mar 2002
    Posts
    52,719
    Central florida
    I doubt pt plywood is going to have a problem with oil, other than absorbing a nice permanent stain.
    You could always apply a sealing agent on the top side, and just clean up the spills before they solvated the sealing agent... or use something more permanent like urethane.
    Soundguy
  9. #19
    Super Member
    Rest in Peace
    frank_f15's Avatar
    Join Date
    Mar 2001
    Posts
    6,033
    BUFFALO ,NEW YORK AREA
    kubota b2400- R4 tires
    bill, why don't u take the pto shaft off the mower and put in further underneath, also i beleive some plastic stapled to the plywood and anchored down in the ground would be better cover for the wheels. as per JM3 TRY AND GET IT OFF THE GROUND. and grease it well.
  10. #20
    Join Date
    May 2002
    Posts
    106
    Way North Idaho Base/US and Canada Territory
    Use from inventory-varies
    Sheds aren't such a problem but when I started my digging for pouring of a cement footing, I checked one more time and found that I was a foot short and a foot too narrow for my drive through tractor/snow mobile building. Plus I knew I would want/need more to store so it expanded in length and width to 20X20. Easier to build it once than add on to.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
