Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default Bolt on Forks?
    Is there such a thing as bolt on forks, if so does anyone know where they may be purchased.
    Thanks
    Frank
  2. #2
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Default Re: Bolt on Forks?
    HI,
    Do you mean palet forks for the loader?
    I have some that sort of clamp on the loader bucket...but they will not work when the tooth bar is on.
    Bill in Pgh, PA
  3. #3
    Platinum Member GregJ's Avatar
    Join Date
    Oct 2002
    Posts
    703
    Washington
    Kubota B7500/LA302FEL/4672BH ; John Deere LX277
    I just bought a 3pt pallet fork attachment. There are clamp on loader attachments, but the capacity its less than a 3pt. Here is a link that shows an example of a clamp on: http://www.carverequipment.com/image...on%20Forks.jpg
    I am using my 3pt forks to palletize my firewood. I can fill a pallet board about 4ft with green maple firewood and still lift it with a B7500 kubota. I tie wrap it with plastic fencing to keep it together. Now I only handle the firewood once when I cut it and once when I bring it into the house. I'm starting to like this tractor more every day.
  4. #4
    Join Date
    Jul 2002
    Posts
    241
    West Michigan
    JD 790, Steiner 230, IH 340U, Farmall Super C, Farmall C, IH Cub Cadet, Wheel Horse 8.75
    Yes there are bolt on pallet forks, they clip to the lower jaw of your loader,
    then you ether tighten a bolt or wrap a chain around the bucket.
    Check around you local tractor or equipment dealers. Just about everyone
    I talked with had or could get ether type of forks.
    I personally didn't like the bolt on type an chose to go with a unit
    that replaced the loader bucket. It was about the same price as
    the clip/bolt type. I chose to go with the Woods model 20 A forks
    but there are other brands but becareful make sure the forks are
    solid not hollow...
    See attachment:
    Attached Images Attached Images
  5. #5
    Elite Member Gary_in_Indiana's Avatar
    Join Date
    Apr 2002
    Posts
    3,388
    Fort Wayne, IN
    John Deere 4200 MFWD HST w/ JD 420 FEL w/ 61" loader bucket & toothbar & JD 37 BH w/ 12" bucket
    There are also some which have sleeves at the top which fit over a bar. The bar is attached to the top edge of your bucket via a couple of hooks. The back of the fork assembly rests against your cutting edge when you lift a pallet or tilt it back. The only negative with these is you can't angle the forks downward unless you attach the lower section to your cutting edge.
  6. #6
    Join Date
    Jan 2002
    Posts
    1,927
    Home-1+ acres New Hope, TX / 24 acres-Fannin County
    JD 950
    Do a search for forks under the attachments forum or the build it yourself forum. There have been several threads on this subject showing a lot of different ideas.
  7. #7
    Veteran Member gerard's Avatar
    Join Date
    Apr 2000
    Posts
    1,681
    Syracuse NY
    Kubota L2500DT w/FEL
    Here's some pics of some forks I made out of some scrap steel I had laying around. Total cost about $15 in materials and strong enough to use with the capacity of my loader (800 lbs)
  8. #8
    Join Date
    Apr 2000
    Posts
    1,681
    Syracuse NY
    closeup view -
  9. #9
    Join Date
    May 2002
    Posts
    106
    Way North Idaho Base/US and Canada Territory
    Use from inventory-varies
    Gerard-
    Its nice to see some innovation and craftsmanship. The forks look good and functional.
    What kind of a backhoe design is on your drawing board?
    Bob
  10. #10
    Join Date
    Apr 2000
    Posts
    1,681
    Syracuse NY
    My skills don't extend quite THAT far! My next project though is to build a bolt on extension to my loader bucket. Plan on adding about 18 inches more to the bottom with sides. Should about double my volume capacity and will work well for moving my piles of mulch, leaves, and horse manure. and hay bales. The stuff is light enough that I won't exceed my lifting capacity and I should be able to do it all out of some scrap 1/4 inch plate steel my brother in law has laying around. (Gonna take some torch time to cut though......)
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
