Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Join Date
    Jun 2002
    Posts
    873
    N Central Ohio
    NH TC35D/SUPER H&M/F-20/JD B&D/FORDSON/JD250 SSL
    Default Re: 54" vs 60" MM Mower - Pros / Cons, Opinions?
    For a small uncut radius (26" if I remember correct)
    I use the 35D w/84" MMM and SS , this is a real nice set-up
    and can trim better than my 110 Deere w/ 38"
    mower.
    Also mows and cut looks better than the L2900 w/
    72" woods RFM.
  2. #12
    Super Member
    Join Date
    Dec 2000
    Posts
    6,737
    JD 8320 MFWD, JD 6415 MFWD, FEL, and cab, John Deere MFWD 4600, John Deere 4020, John Deere 4430, John Deere 455 mower, Deutz, and Gehl 4610 perkins skidsteer
    I agree with Tres Crow. Go with the bigger deck. If time is important to you it will cut your time quite a bit on that deck. Also like has been said the anti-scalping is nice as well.
  3. #13
    Join Date
    Jun 2002
    Posts
    209
    Southeast Iowa
    Kubota B3200
    Default Re: 54
    I had a John Deere 318 with 50" deck for many years. I now have a kubota BX2200 with 60" deck. My vote goes to the 60".
  4. #14
    Join Date
    Jun 2002
    Posts
    75
    Illinois
    JD 4010
    Default Re: 54
    I have a 4010 with a 60" deck and I have had no problems at all. The HP is adequate for the size and it is very well built. I mow ditches as well as other uneven ground and have had no problems with scalping. I would reccommend going with the 4110 only because of the control you have with the rockshaft lever.
    Brent
  5. #15
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Thanks for all the help.
    I am going to go with the 2210 and a 62C Mower deck
    Thanks
    Fran
  6. #16
    New Member
    Join Date
    Sep 2005
    Posts
    0
    Hi, Just wondering why you picked the 2210, I have been looking at the 4010 and 2210 as well.
    Glen
  7. #17
    New Member
    Join Date
    Sep 2005
    Posts
    0
    It was a tough decission, just about a toss up between the both.
    Here are some basic comparisons:
    Weight - about the same - no advantage to either on
    HP - 2210 - better for larger mower deck / PTO implements
    Hyd - 4010 - better for Hyd implements, larger FEL load capacity.
    Size - 2210 - a little smaller - better for my purposes
    Overall - for my small piece of land, and the fact that I will probably use the MMM more than anything else the 2210 was better for my particuliar needs. I think if I was expecting to use the FEL more, I would probably have picked the 4010 over the 2210. It would be very easy to just go the bigger is better route, but You have to realisticly look at your current, and planned future uses and make your decission based on that.
    Good Luck
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
