SrChf
Being a RCH away from buying a BX25 with MMM, I cannot shake the thought that I am going to dislike mowing my lawn with this big thing (considering I prolly need to take off the backhoe and front loader each week to do it) as compared to just firing up and hopping on to a new tight turning riding mower for about the same cost.
I see there are two ways to look at this - a second machine is more maintenance, more moving parts, etc, on the other hand, now I can still mow my yard should the BX go Tango Uniform.
So I suppose the main question is to you that mow your lawns regularly with your BX25 TBL (or equivalent SCUT)? If you owned a $2000 riding lawn mower sitting there, would you still hop up on you BX and do your lawn with it?
Granted, it surely depends a lot on the yard. No brainer if you have a massive multi acre field of saw grass to hack down. Mine is one small acre of land of common weeds and (a little) grass, not too many hills but several massive trees to steer around.
Thoughts?
Thoughts?
